reverse light doesnt work need help!!!!
Old Sep 3, 2007 | 01:36 PM
trick_db's Avatar
Default reverse light doesnt work need help!!!!
my reverse light doesnt work, Just seeing what the cause of this. I think is the fuse, but not really sure. IF anybody can help that would be great.
btw is a 98 integra.
Old Sep 3, 2007 | 01:48 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (trick_db)
ttt
Old Sep 3, 2007 | 02:02 PM
hatchling37's Avatar
Could be the fuse, could be you have a bad reverse signal switch.
Old Sep 3, 2007 | 03:55 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (hatchling37)
i dont know about the signal switch, but i think before i bought the car it was working fine... anymore? if so what number fuse? like is the fuse that is under the bay or under the dash.
Old Sep 3, 2007 | 05:06 PM
trick_db's Avatar
so nobody knows?
Old Sep 3, 2007 | 05:22 PM
wildcat98's Avatar
the fuse should be under he dash ....... if that is ok check the the switch on the gearbox/ tranny
Old Sep 3, 2007 | 09:24 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (wildcat98)
can anybody tell me what fuse is it? cause i lost the diagram and i dont want to pull everything out.
Old Sep 4, 2007 | 02:30 PM
chocolatesk8er10's Avatar
could be the bulb, i just changed mine out yesterday. the bulb # is 1156
Old Sep 4, 2007 | 07:52 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (chocolatesk8er10)
i check the bulb both of them is fine, but i probably will have to check it again. Anymore advice? please help!!!
Old Sep 4, 2007 | 08:17 PM
db1_jdm's Avatar
just jump the reverse switch using a paperclip...its stick right?
Old Sep 4, 2007 | 08:34 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (db1_jdm)
i dont know how to do that, instruction? anymore?
Old Sep 4, 2007 | 11:40 PM
db1_jdm's Avatar
ok turn the key to on position and jack up the car (safely using jackstands) look at the front of the tansmission there should be a sensor( it really is a switch) disconnect it and at the connector jump it using a paper clip, if suddenly ur reverse lights come on then u automatically know its ur switch thats bad... if they dont then check for power and ground at the pins u should be getting around 12v both negative and positive...if u dont get power then u know it is a fuse if u dont get ground then u know its a ground connection somewhere,,(refer to wireing diagram)...
Old Sep 5, 2007 | 08:45 AM
dc2 frm da island's Avatar
BUY A NEW BULB LIGHT!
Old Sep 5, 2007 | 01:35 PM
trick_db's Avatar
Default Re: reverse light doesnt work need help!!!! (dc2 frm da island)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2 frm da island &raquo;</TD></TR><TR><TD CLASS="quote">BUY A NEW BULB LIGHT! </TD></TR></TABLE>
um is not the bulb i check it so many times.... and please dont tell me to check it cause is not.
Old Sep 5, 2007 | 06:38 PM
trick_db's Avatar
any helps? if so whats the fuse number? i want to check it out. i lost the diagram and i dont want to keep pulling out all the fuse
Old Sep 5, 2007 | 08:32 PM
db1_jdm's Avatar
lol bro turn the key on and check every fuse using a test light, after u have tested the reverse switch
Old Sep 5, 2007 | 08:35 PM
trick_db's Avatar
hahahah, i dont even have the diagram and is dark outside. I dont even want to bother lookign under the car right now. California weather is weird. Be ******* hot lately. just tell me what fuse the reverse tailight is? thanks.
Old Sep 6, 2007 | 07:17 AM
trick_db's Avatar
ttt
Old Sep 7, 2007 | 08:57 AM
trick_db's Avatar
bump it.
Old Sep 7, 2007 | 06:14 PM
db1_jdm's Avatar
got ur **** fixed yet?
Old Sep 7, 2007 | 06:49 PM
wegotmorrison's Avatar
I wouldnt take advice from him, somehow your car would end up getting stolen..
Old Sep 8, 2007 | 04:01 PM
trick_db's Avatar
not yet, been really busy with work/school. Ima check the switch when i have the time. can anybody can just tell me right now what the tailight fuse is? i lost my diagra.
Old Sep 8, 2007 | 04:31 PM
TIMMY4TOES's Avatar
ok, i feel bad 4 you, this can be a bitch. this is how you find out 1000% sure if its the fuse or not. ready ready ready ready ready.
HONK THE HORN.
if it doesnt sound its the fuse. they are wired to together.
even if you cant find the diagram, you could just pull them out one by one and c if one is burned. its still faster than wasting all your time listening to other HONDA "pros"
I dont mean to be a azz, but alot of these people on this site make problems alot harder than they are.
Jack of all trader, Master of none
Old Sep 15, 2007 | 07:31 AM
db1_jdm's Avatar
Default Re: reverse light doesnt work need help!!!! (TIMMY4TOES)
i can honestly agree with this guy, yeah ur horn is in the same circuit..just for kicks though also jump ur reverse switch using a paper clip, (key on engine off) if the lights all of sudden turn on then its ur reverse switch
Canucksfan101
Dec 31, 2014 03:02 PM
TNight
May 20, 2014 03:58 AM
dc4teg95
Jul 27, 2013 02:07 PM
Civic-Kids
Audio / Security / Video
Feb 22, 2010 10:30 AM
VTECcivicDOWORK
Jun 17, 2008 08:23 AM
