Injector question please help
With the P13, you can use low impedance peak and hold injectors with it - which, luckily, most higher-flow injectors are...
If you are looking for stock, you can use the 310cc injectors from 1993-96 Prelude VTECs. (But not the 97+ Prelude injectors without some rewiring and compromise.) Or you can use any number of aftermarket injectors if you want to go larger. RC Engineering is a company that sells in many sizes in both low and high impedance types. If you are looking for inexpensive, some people use DSM turbo injectors which are like 450cc. From what I've heard, the DSMs are not a bolt-in though. I believe h-t member apexii has DSM injectors on his turbolude...
Andrew
Andrew
