Really Really unusal!.. NEED HELP.
Ok, so im driving in my 96 Accord and.. im going maybe..mm..40mph.. when all of a sudden my.. speedometer gauge goes from 40 to 0 and then goes back and forth maybe about..5-6 times. Check engine light does not come on.. and it goes back to normal. I drove the car around for maybe..20 minutes after that had happend and it seems to be working fine. Anyone know what that meant or why it did that?
I suspect, if it happens again you'll be looking at replacing the Cluster Assembly.
If it had been either the VSS (Vehicle Speed Sensor) or the ECM (Engine Control Module), it would have set a code, the lamp would have come on and other funky things would have happened.
P
P
do you have an amp for your stereo? or anything thats aftermarket and drawing current and needs positive and neg?
Something like this happened to me when i had a bad install for my amps. when i would click on the high beams the speedo would drop to 0 and then back up. it was actually when i did anything that required power. after redoing the amp install it was perfect again. i think maybe the power wire was touching the body of the car, since my subs would only pop and made no noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">I suspect, if it happens again you'll be looking at replacing the Cluster Assembly.
P</TD></TR></TABLE>
actually i had the vss on my civic start having problems and didnt throw a code until it did it at least 3 or 4 times.
so he could still have an issue with his vss. i would take it out and clean it and inspect it
P</TD></TR></TABLE>
