RRR ITB's worth IT!!!!!!
Old Jan 3, 2006 | 12:25 PM
mer2ski's Avatar
Default RRR ITB's worth IT!!!!!!
Are ITB's really worth it, I"m working on a D16a6 bottom with a1 piston z6 head, exospeed cam, bisi header, mild P&P and hondata s300 management. I'm working on a set of CBR 929 ITB's but am wondering if there really worth all the extra work? How much WHP can I make with this set up? Will I at least be in the 170 range? What kind of gain can I expected over Fuel Injection?
Old Jan 3, 2006 | 04:47 PM
SETI20's Avatar
Default Re: RRR ITB's worth IT!!!!!! (mer2ski)
It'll gain you some...but it's no miracle solution.
ITB's are designed for throttle response. Not power.
And YES they are worth it.
Old Jan 3, 2006 | 05:56 PM
dr_latino999's Avatar
Default Re: RRR ITB's worth IT!!!!!! (SETI20)
If you have a horrible intake manifold setup to begin with, would ITB's not appear to make you power under the idea of less restriction?
Old Jan 3, 2006 | 06:11 PM
SETI20's Avatar
yeah, that's true.
Old Jan 3, 2006 | 08:01 PM
ef2_civic's Avatar
Default Re: (SETI20)
well at least u got the right management for it I got s200
should trade up for a s300
Old Jan 3, 2006 | 08:25 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: (ef2_civic)
Hondata is a waste for n/a d16
You wont be in the 170 range unless you pull some crazy timing
Old Jan 3, 2006 | 10:10 PM
SETI20's Avatar
hm... I think 170 at the crank might be pushing it a bit too.
Old Jan 4, 2006 | 01:57 AM
RaCk's Avatar
Why not do a B swap while you're at it?
Old Jan 4, 2006 | 05:35 AM
mer2ski's Avatar
I have the engine laying around and have a set of p29 i got a hold of for 20 bucks, so i figured i will tinker with it a bit. Also I'm pretty new at this and I figured to go the cheaper rought and learn as much as posibble about(tuning, engines,set-ups,and making power) I have a d16z6 turbo currently and I make pletty of power but I have obd 0 and the tunning sucks. The s300 is just an investment so I could teach myself how to tune. I will be working on a B-series in about a year for another HB.
Bottom Line How much Power will I make??????
Old Jan 4, 2006 | 09:49 AM
SETI20's Avatar
That's dependant on soooooooo many variables. No-one will know. If all goes well you might end up in the 150 range. But that's a guesstimate.
Do the work, and dyno it. That's the only way you'll find out.
These engines do have great response and pickup tho. That's where your advantage is going to be. Not in the raw power band.
Old Jan 4, 2006 | 05:49 PM
mer2ski's Avatar
I'll try and post pic's of the build and the dyno results soon, thanks for your info>>>>
Old Jan 4, 2006 | 06:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">hm... I think 170 at the crank might be pushing it a bit too.</TD></TR></TABLE> On stock bore, I will second this without some non-streetable toys going into the equation.
Old Jan 4, 2006 | 07:35 PM
kyles1988's Avatar
Default Re: (dr_latino999)
either way, ITB's are teh hawtness
Old Jan 5, 2006 | 01:13 PM
mer2ski's Avatar
do you guy's think that if I got a set of .40 over pistons, it would make any diffrence???
jesse0880
Jul 10, 2018 11:48 AM
x still jaded x
Nov 16, 2006 03:46 PM
sohctodohc
10
Jan 31, 2006 09:40 PM
jdmefhondachassis
Jun 30, 2004 07:20 AM
DC5racer
Nov 18, 2003 02:35 PM
