B16a driveabilty issues
Old Mar 19, 2002 | 10:06 AM
4g4me's Avatar
Default B16a driveabilty issues
I recently put a b16a into my 91 hf, and it runs good except for one thing. When you are driving in 5th, at a constant speed, the motor starts sputtering. I give the car a little gas, sputters more. I press the pedal to the floor, sputtering stops, car accelerates. Then after that the car runs awesome for like a minute or two, then starts again. I also experience this if I accelerate really slow like in second gear, it will sputter till I push the pedal a lil bit. There are a few things i have tried. I have played with my cam and my ignition timing-nothing. I have played with the vaccum hoses, and sensors-nothing. The car will do this when it is cold, and when it is at normal temp. I have no check engine lights and no codes are flashing. I don't know what to do next. ANYONE ever experience this? Could this be distributor related? HELP!
Thanks for reading.
Old Mar 19, 2002 | 10:58 AM
4g4me's Avatar
Default Re: B16a driveabilty issues (4g4me)
bump
Old Mar 19, 2002 | 11:29 AM
RexB16's Avatar
well its DEFINATELY fuel/ignition related. check the rotor on the dist. my mony is on that or the dist itself.
Old Mar 19, 2002 | 12:50 PM
4g4me's Avatar
thanks, can I get a second on that? Opposition?
Old Mar 19, 2002 | 12:55 PM
RexB16's Avatar
also could be clogged injectors or a clogger fuel filter. maybe even a tired fuel pump.
Old Mar 19, 2002 | 01:18 PM
91lsvtec's Avatar
Default Re: B16a driveabilty issues (RexB16)
I would definitaly go with a fuel issue also. Have you checked to see if the throttle body is sticking? We've had a few issues whit those lately.
Old Mar 19, 2002 | 01:51 PM
E-AT_me's Avatar
Default Re: B16a driveabilty issues (91lsvtec)
definately run some throttle body cleaner through it and some fuel injector cleaner. my friends RX7 did that, too. it was the fuel injectors.
Old Mar 19, 2002 | 07:02 PM
fastwanabe's Avatar
Default Re: B16a driveabilty issues (Rexman)
check the distributor rotor for signs of walking, the rotors are notoriuos for this!!!
Old Mar 20, 2002 | 02:55 AM
samiam's Avatar
Shiet that happend to me too ended up being the crank sensor being bad (no ac sine wave) well it was intermittent, so i changed it just like brand new.
speedfreak44
Feb 3, 2014 04:30 PM
Si-Samuri
Jul 6, 2010 09:11 AM
stubrun
May 17, 2010 12:48 AM
EGLUVN
Aug 23, 2007 01:39 PM
LITTLERIGGY_b16A
Mar 26, 2007 05:23 PM
