1995 Obd1 GSR swap, Fully Built/Rebuilt with only 8k miles on it! Southern New Jersey! Very Cheap, T
OBD1 GSR B18C1 Swap, Fully rebuilt/built with CTR tranny. FULL SWAP
Asking<FONT COLOR="green"> $4,000.00</FONT>
Fully Rebuilt around 8k Miles ago.
Rebuild Included:
Bottom End
Brand new .25 over JDM ITR pistons w/ rings.
Brand New ITR Oil pump, Water Pump, and Timingbelt.
Has Newer Timing covers and cog gear to allow for the newer style OBD2 Oilpump.
Brand New OEM Headgasket
Has Brand new CTR N1 Crank pulley.
Machine work inlcuded Bore .25 Over, Hone, And Decked to specs
Cylinder Head
Skunk2 Stage 2 Cams On stock Cam gears
Omni Power Valve Springs & Retainers
Skunk2 Intake Manifold
Head was milled to specs
Drivetrain
99 CTR Tranny : No grinds, No Seals leaking, No Noises
ACT 12lb Flywheel
ACT 6 Puck Unsprung Clutch w/ Heavy duty PP
Pictures will be up shortly
Only trades are for K series in DC mounts,axles,harness,K-Pro or Pistons/rods /Motor Parts.[/b]
Modified by RHDej2. at 6:07 PM 1/6/2006
Rebuild Included:
Bottom End
Cylinder Head
Drivetrain
ACT 12lb Flywheel
sick set up, i would be interested.. im bout to have 1 or 2 ls swaps.. i still got mad **** for sale too always.. ttyl
anothersickhatch
Oct 19, 2006 05:18 PM
NJcoupe
Dec 16, 2004 11:32 AM
