what is a defouler?
Old Jan 2, 2006 | 08:52 PM
o1geeser's Avatar
Default what is a defouler?
i have heard people use spark plug defoulers but i dont really know what that is?
Old Jan 5, 2006 | 02:52 PM
whiteDCfiver's Avatar
Default Re: what is a defouler? (o1geeser)
People use a defouler on the secondary o2 sim to fool it into thinking there is a catalitic converter. The defouler is a part you can buy at autozone for like 4 bucks. You have to bore it out to a 1/2 inch. Its better to use 2 of em. The o2 sim then goes inside the defouler creating more distance btw the sim and exhaust pipe. This distance somehow fools it.
Heres a pic
Old Jan 5, 2006 | 03:03 PM
BarracksSi's Avatar
I've understood that the O2 sensor is looking for a certain amount of exhaust flow. In a test pipe, the flow is obviously faster than in a catalytic convertor, so the sensor spots the difference and generates an error. Put a couple defoulers in the way, and the sensor sees less flow -- approximately the same as if there were a cat. It doesn't notice anything wrong, so it won't generate an error.
At least, that's what I've been told.
Old Jan 6, 2006 | 12:40 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (BarracksSi)
whats the purpose of it? just to run no cat?
Old Jan 6, 2006 | 08:14 AM
NJslvrtypes's Avatar
Default Re: (Redline96LX)
It goes on your race header or test pipe so you don't throw a CEL for not having a catalytic converter. The sensor is not in the direct flow of the exhaust gases so it usually fools the ecu into thinking the cat is doing its job.
Old Jan 6, 2006 | 08:56 AM
o1geeser's Avatar
Default Re: (NJslvrtypes)
thanks for the input! what do i need to bore out?
Old Jan 6, 2006 | 12:48 PM
Default Re: (o1geeser)
1/2" Drill Bit
Heres a DIY
http://forums.clubrsx.com/showthread.php?t=296791
rebuiltSI
Jun 29, 2007 05:56 AM
bloodydc2
Jul 18, 2006 02:25 PM
IntegraCF21
Sep 24, 2005 04:42 AM
maxxdout
Oct 1, 2001 11:20 PM
kikkoboyie
Aug 13, 2001 08:33 PM
