what is a defouler?
Old 01-02-2006, 08:52 PM
o1geeser's Avatar
Default what is a defouler?
i have heard people use spark plug defoulers but i dont really know what that is?
Old 01-05-2006, 02:52 PM
whiteDCfiver's Avatar
Default Re: what is a defouler? (o1geeser)
People use a defouler on the secondary o2 sim to fool it into thinking there is a catalitic converter. The defouler is a part you can buy at autozone for like 4 bucks. You have to bore it out to a 1/2 inch. Its better to use 2 of em. The o2 sim then goes inside the defouler creating more distance btw the sim and exhaust pipe. This distance somehow fools it.
Heres a pic
Old 01-05-2006, 03:03 PM
BarracksSi's Avatar
I've understood that the O2 sensor is looking for a certain amount of exhaust flow. In a test pipe, the flow is obviously faster than in a catalytic convertor, so the sensor spots the difference and generates an error. Put a couple defoulers in the way, and the sensor sees less flow -- approximately the same as if there were a cat. It doesn't notice anything wrong, so it won't generate an error.
At least, that's what I've been told.
Old 01-06-2006, 12:40 AM
* B A N N E D *
Redline96LX's Avatar
Default Re: (BarracksSi)
whats the purpose of it? just to run no cat?
Old 01-06-2006, 08:14 AM
NJslvrtypes's Avatar
Default Re: (Redline96LX)
It goes on your race header or test pipe so you don't throw a CEL for not having a catalytic converter. The sensor is not in the direct flow of the exhaust gases so it usually fools the ecu into thinking the cat is doing its job.
Old 01-06-2006, 08:56 AM
o1geeser's Avatar
Default Re: (NJslvrtypes)
thanks for the input! what do i need to bore out?
Old 01-06-2006, 12:48 PM
Default Re: (o1geeser)
1/2" Drill Bit
Heres a DIY
http://forums.clubrsx.com/showthread.php?t=296791
rebuiltSI
06-29-2007 05:56 AM
bloodydc2
07-18-2006 02:25 PM
IntegraCF21
09-24-2005 04:42 AM
maxxdout
10-01-2001 11:20 PM
kikkoboyie
08-13-2001 08:33 PM
Quick Reply: what is a defouler?
