test pipe questions??
Old Sep 25, 2001 | 07:53 AM
maxxdout's Avatar
Default test pipe questions??
ok,
header is on the way, and i have read posts about guys that run a test pipe or cat replacement pipe,...whichever you prefer. few questions: If i get the measurements and deminsions do you think a local muffler shop could fabricate one? Is there anything special about it? does it need to have an O2 bung set in?
And also, in your oppinions...for occasional use is it worth it??
Old Sep 25, 2001 | 08:26 AM
owen_the_soyboy's Avatar
Default Re: test pipe questions?? (maxxdout)
easy to make one.
use a resonator/cherrybomb if possible for a deeper tone.
measurements are needed, as well as orientation of the two flanges relative to each other and relative the O2 sensor bung location.
O2 sensor location may be needee as well.
I cant remember if OBD2 cars have two O2 sensors in the cat...?
Old Sep 25, 2001 | 09:15 AM
Kalokohan's Avatar
New User
Default Re: test pipe questions?? (owen_the_soyboy)
OBDII cars has a sensor on the end of the headers, and one on the end of the cat. Any muffler shop should be able to make you one.
Old Sep 25, 2001 | 10:16 AM
Chris's Avatar
They should be able to make to make you one, but good luck getting them to....
Big fines if they are caught. I think if they do not install it you would be fine.
Old Sep 25, 2001 | 12:05 PM
pstreck's Avatar
New User
Default Re: test pipe questions?? (Chris)
it's not illegal to make a test pipe, just to run them on the street. you can run it on the strip all day... but who wants to keep flip floppin
Old Sep 25, 2001 | 01:11 PM
kikkoboyie's Avatar
New User
Default Re: test pipe questions?? (pstreck)
not i
Old Sep 25, 2001 | 10:40 PM
na96gsr's Avatar
New User
Default Re: test pipe questions?? (kikkoboyie)
If i remember right, both the sensors are on cat on my '96 gsr. So if i got a cherry bomb to replace my cat, I would have to have the muffler shop fit the sensors onto the cherry bomb? I was looking at a test pipe awhile back because i was replacing my header. After i noticed the location of the sensors, and no one around here knows anything about it. I just didnt mess with it, but i never thought about a cherry bomb. If i leave those 2 sensors out if i do a cherry bomb, would that **** **** up?
Old Sep 26, 2001 | 05:55 AM
bigTom's Avatar
u would mess urself up if u leave the o2 sensors out... and considering u ave obd2... if u put a test-pipe in welcome to the world of the CEL!
Old Sep 26, 2001 | 10:12 AM
maxxdout's Avatar
Default Re: test pipe questions?? (ek9t)
so do i have to remove the cat and have them measure it out to make one, that means having to drive around without anything...not cool. If i could find somewhere that as the deminsions of the test pipe fr construction could i just give them that info or do they need to have the cat there to properly construct it?
Old Sep 26, 2001 | 02:12 PM
maxxdout's Avatar
anyone??
Old Sep 26, 2001 | 05:48 PM
Prelussion's Avatar
I've seen them forsale online and for sale on Ebay, some people who make them but make a little extension out the side of the pipe containing the cat converter fibers where the o2 senson plugs in, I'm not sure if this is what you guys are calling a cherry bomb or not.
Old Oct 1, 2001 | 11:20 PM
na96gsr's Avatar
New User
Default Re: test pipe questions?? (dc2jdmhonda)
So since i have obd2, is there a way i can put a test pipe on? Or am i stuck with the cat? Like say, when you run straight headers your header is not connected to the cat. But the cat is there with the o2's pluggd in. I did that once for the track, but would be cool to put a test pipe in if possible.
95acuraintegra
Jan 8, 2009 04:54 PM
rebuiltSI
Jun 29, 2007 05:56 AM
bloodydc2
Jul 18, 2006 02:25 PM
IntegraCF21
Sep 24, 2005 04:42 AM
EKB18BPR3
Jul 7, 2003 10:50 AM
