Averaqge oil temps on boosted b-series?
Old Jan 2, 2006 | 06:22 PM
wantboost's Avatar
Who is Mr Robot?
Default Averaqge oil temps on boosted b-series?
as topic states, just curious for those that monitor it
Old Jan 2, 2006 | 07:31 PM
blackeg's Avatar
Default Re: Averaqge oil temps on boosted b-series? (wantboost)
my boosted ls was just about 165F almost all the time. i only saw temps of 205-210 a few times, and that was boosting on highway trips during the middle of the summer.
Old Jan 2, 2006 | 07:35 PM
Finland's Avatar
Usually it takes about 5 minutes of easy driving to get to about 140F, then it climbs to about 180ish, and eventually settles to about 190ish. If I drive her hard, she'll hit 210-220. It's never exceeded 220 even after repeated 1/4 mile runs. I run the Moroso 5 quart aluminum pan and synthetic oil.
Old Jan 2, 2006 | 08:05 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Mr. Helsinki)
Usually the oil temp follows the water temp. Sometimes it gets hotter, but most of the time in the winter it stays cooler. Ive seen mine hit about 225 when my idle was stuck @ 3k....
Blaze
Old Jan 2, 2006 | 08:07 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Blaze45)
thanks guys, just trying to figure out what to do for an oil cooler... i found one that uses engine coolant... mine nevers gets about 1801-90 so i think ill get it
Old Jan 2, 2006 | 09:14 PM
Riake's Avatar
Default Re: (wantboost)
This may or may not help because im not boosted yet but, in the hot Florida summer I just experianced with the new guage I got a max of 180F. This was on the highway. Normally it was 150, and now sometimes it hardly gets above 100 in the winter now, but occasionaly it does.
Old Jan 2, 2006 | 10:10 PM
_gurusan_'s Avatar
Default Re: (Riake)
I have a fluidyne 6 row cooler that I might sell actually.
Maybe I'll keep it.
I'm just wondering....would I have any oil pressure problems running a remote oil with the cooler inline of the filter and block, then having the turbo feed line tapped into the same line?
Right now I plan on ditching the cooler until i am boosted and see how my oil temps are.
Old Jan 3, 2006 | 04:59 AM
Joseph Davis's Avatar
Oil temp needs to go over boilling point of water occaisionally, to evaporate the water vapor that makes it past the rings and becomes lodged in the oil.
Oil temp affects engine tune, just like coolant temp, and an oil cooler (esp in winter months) can influence your tune if you run one of the Honda ECU-based systems. Engine temps get too cold and you get more fuel and more ignition timing.
Old Jan 3, 2006 | 06:50 AM
Chris F's Avatar
Default Re: (J. Davis)
300-315F
-Chris, already has an oil cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Oil temp needs to go over boilling point of water occaisionally, to evaporate the water vapor that makes it past the rings and becomes lodged in the oil.
Oil temp affects engine tune, just like coolant temp, and an oil cooler (esp in winter months) can influence your tune if you run one of the Honda ECU-based systems. Engine temps get too cold and you get more fuel and more ignition timing.</TD></TR></TABLE>
Sound advice. My GReddy oil cooler has a thermostat that seems to work. It's probably a good idea for a street car.
-Chris
JMelt4
24
Apr 30, 2007 04:42 PM
realis9
May 23, 2006 08:55 PM
Boilermaker1
11
Apr 11, 2005 07:41 PM
577HondaPrelude
Apr 6, 2003 11:56 AM
BlowOff
Jun 28, 2001 08:33 AM
