how much psi dose the fuel & oil run on a honda?
Old Jan 2, 2006 | 12:12 PM
spooledhonda's Avatar
* B A N N E D *
Default how much psi dose the fuel & oil run on a honda?
Old Jan 2, 2006 | 12:17 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: how much psi dose the fuel & oil run on a honda? (spooledhonda)
Old Jan 2, 2006 | 12:25 PM
BlueShadow's Avatar
IIRC stock fuel pressure is around 45psi under vacuum. On a stock/aftermarket 1:1 ratio FPR when you are in boost your fuel pressure is increased 1 psi for every pound of boost. So if you are running 18 psi of boost your fuel pressure is base fuel pressure plus boost psi equals total fuel pressure or 45+18=63 psi of fuel pressure at 18 psi of boost. An FMU is the same way...say if you have a 12:1 FMU and are running 7 psi. Your fuel pressure under vacuum is 45psi, but once you have reached 7 psi you will have 45+84=129 psi total fuel pressure. That's because each pound of boost raises the fuel pressure 12 psi with a 12:1 ratio FMU.
Old Jan 2, 2006 | 12:43 PM
Adriano's Avatar
Default Re: how much psi dose the fuel & oil run on a honda? (BlueShadow)
Fuel pressure should be at 45psi without the vacuum line hooked up. And oil pressure varies from 20-80 depending on what rpm you area at.
Adriano
Old Jan 2, 2006 | 01:49 PM
* B A N N E D *
oh and by the way the motor is an LS or B18b1 and i am boosting it.
Old Jan 2, 2006 | 02:16 PM
White Smoke's Avatar
i my honda
Global Mod
I vote ban
Good oil pressure is around 60-80 psi mild throttle. It can be as low as 30 and as high as 90 depending on RPM and temp.
Old Jan 2, 2006 | 05:18 PM
* B A N N E D *
ok, so i wanted to get an oil press gauge they gome in 100psi and 200 psi i should get the 100 pis one then rite?
Old Jan 3, 2006 | 10:02 AM
kuja's Avatar
Default Re: (spooledhonda)
100 should be fine, i think thats what my defi goes to.
Old Jan 3, 2006 | 01:07 PM
i my honda
Global Mod
Default Re: (kuja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja &raquo;</TD></TR><TR><TD CLASS="quote">100 should be fine, i think thats what my defi goes to.</TD></TR></TABLE>
Mine goes to 10 bar so... 140psi
Old Jan 3, 2006 | 01:42 PM
kuja's Avatar
Default Re: (White Smoke)
yea thats right
Old Jan 3, 2006 | 01:54 PM
beepy's Avatar
Default Re: (kuja)
10 bar = 145 PSI.
Old Jan 3, 2006 | 03:23 PM
Muckman's Avatar
Moderator in Chief
uno dose tres!
civicjoe
Mar 8, 2008 12:51 PM
hotimportcrx
Feb 4, 2005 08:31 PM
Quick 200k Mile Motor
Jun 29, 2003 05:48 PM
b16ahybrid
Nov 28, 2002 07:51 PM
JM Performance
Nov 28, 2001 03:46 PM
