Mini-Me Timing Question and more...
Old Jan 1, 2006 | 07:05 PM
freakasis's Avatar
Default Mini-Me Timing Question and more...
ok, i have a y7 bottom end with a p-08 head (z6??)...the cam gear is five spoke (i was told this was y8??) i have no idea what cam is in there and i need to set the timing. i have read that the y8 and z6 cams have differant timing...my timing marks on dead on and it wont run....it has spark, fuel, and the computer works, no cels and the timing belt is a little loose. i think it jumped timing but i dont know where to set the cam gear.
can anyone tell me if it needs to be set "wrong" and by how much? or what head i have? if you need any pics just ask and ill take em.
thanx.
Old Jan 1, 2006 | 09:19 PM
freakasis's Avatar
anyone?
Old Jan 1, 2006 | 09:48 PM
Luserkid's Avatar
Default Re: Mini-Me Timing Question and more... (freakasis)
Check the year of the head if its anything older then 96 then its a y8. If you still have your original y7 head check the cam gear on it because y7 and y8 share the same gear. What belt are you using as well.
Old Jan 1, 2006 | 10:18 PM
freakasis's Avatar
Default Re: Mini-Me Timing Question and more... (Luserkid)
i baught the car this way so i have no idea. if i did it myself i would have just looked and the combustion chambers. the head was made in 95 if i read it right...so that means it could have been an early model 96 ex or a late model 95 ex....the cam gear is 5 spoke, which i was told by someone is a y8 if is a y7/8 cam gear and a z6 cam than the timing marks arent lined up at perfect timing...right?
Old Jan 1, 2006 | 10:36 PM
Contender25
Guest
Posts: n/a
You need to either switch cam gears and tune it out, or buy a tighter belt, via a 1.5 belt with a few teeth less possible so it won't jump timing.
Old Jan 1, 2006 | 10:38 PM
wob's Avatar
wob
my z6 cam gear had no spokes, u said the belt is loose, did they use a z6 timing belt.. after setting base timing a 0 did u set ignition timing to 16*btc
Old Jan 1, 2006 | 10:44 PM
underb00steg6's Avatar
i thought for a mini-me swap the crank pulley has to be changed out for whatever you have.....
Old Jan 2, 2006 | 07:37 AM
freakasis's Avatar
i was told that the z6/y8 cam gears had differant timing marks...my timing is set dead on...the problem is i dont think it should be dead on because of the wrong gear on the head....my question in which way do i set the timing off and by how many degrees/teeth?
Old Jan 2, 2006 | 11:25 AM
Contender25
Guest
Posts: n/a
If i remember correctly you're suppose to retard the timing 1-2 teeth or degree's, thats all i remember from my mini me swap from a year ago from today.
Old Jan 2, 2006 | 12:18 PM
robert_v's Avatar
Default Re: (freakasis)
i'm not sure either but i just did my timing using the repair book and it came out at 16*.
thatseemslegit
42
Sep 17, 2015 09:07 PM
dustinbs144
Jul 15, 2010 01:56 AM
EARLdaSQUIRREL
May 7, 2009 02:14 PM
xsenceo89x
Dec 27, 2007 11:45 AM
