What could be causing this mess?
Old Jan 1, 2006 | 05:35 PM
mkazm83's Avatar
Default What could be causing this mess?
I was just under my car and noticed that the trans is covered in grease and fluid. Where could this be comming from? Here are some pics I took.
I forgot to add, the car is garaged every night and there is no oil spots on the ground.
Old Jan 1, 2006 | 05:38 PM
The Weather Man's Avatar
Check the drain and fill plugs.
It actually looks like the grease that is put in the cv boots.
Old Jan 1, 2006 | 05:42 PM
6E LUDE's Avatar
Dirt and grim from the road?
Old Jan 1, 2006 | 05:43 PM
mkazm83's Avatar
Default Re: (TheKINGPin)
I will, im pretty sure they are tight. I think youre right about the grease heres another pic.
Niles's Avatar
I agree with The King Pin and also suggest checking for a torn CV boot. It looks like the grease has been thrown from the boot.
Also looks like some oil in places, which usually comes from sloppy oil changes.
Old Jan 1, 2006 | 05:46 PM
6E LUDE's Avatar
Yea that pic shows it all, thats def your CV boot grease. Look at the spray pattern. So PRETTY
Old Jan 1, 2006 | 05:49 PM
mkazm83's Avatar
Default Re: What could be causing this mess? (mkazm83)
I forgot to add, the car is garaged every night and has never had oil/fluid spots on the ground.
That oil/grease on the other side of the trans drain/fill plugs as well.
Modified by mkazm83 at 7:00 PM 1/1/2006
Old Jan 1, 2006 | 06:01 PM
Yep. I say check for boot.
Its an easy replace - if you can't find a tear, see if its not tight enough.
Old Jan 1, 2006 | 06:40 PM
Hawkze_2.3's Avatar
I have that same exact leak and after removing the tranny and doing a lot of inspection it appears to be coming from the 'shift arm cover'....number 6 in this picture---.
There are a few oil seals and such in there that I plan to replace in the future...maybe that's where your leak is also because it's DEFINATELY not axle grease...
Old Jan 1, 2006 | 11:18 PM
mkazm83's Avatar
Default Re: What could be causing this mess? (Hawkze_2.3)
^^That area is relatively clean, Im wondering if the cam seal could be to blame for the oil residue. There is oil residue where the yellow arrows are pointing.
Modified by mkazm83 at 1:08 AM 1/2/2006
Old Jan 2, 2006 | 10:19 AM
SteveoBA8's Avatar
that cam seal is known to leak, get an aftermarket multi o-ring seal
imacoolkid
Nov 6, 2009 08:00 AM
life sux die
Sep 4, 2006 08:04 AM
rainmanEK
Dec 10, 2002 12:50 PM
itrQ
Mar 13, 2002 03:16 AM
