FS: Going turbo on Built H22...need some advice
Old Mar 19, 2002 | 02:04 AM
import-store's Avatar
Default FS: Going turbo on Built H22...need some advice
Debating whether to go buy just a turbo kit, or piece it doing custom turbo...if i do a custom turbo setup, is it really worth it to save money? Need some help on this. Bought the apexi GTR Core already, pretty much i was thinking i just need the t3/t4 turbo, manifold, downpipe, wastegate, flanges, hoses and fittings, all the other parts like the bov, etc thats not a problem.
Old Mar 19, 2002 | 04:10 AM
Mikey3000's Avatar
Default Re: FS: Going turbo on Built H22...need some advice (import-store)
i don't think piecing your own kit together saves money, it just lets you pick all the stuff out yourself. i.e. tial wastegate instead of deltagate, greddy bov instead of turbonetics, apex ic instead of spearco etc. actually, i think it'll cost more to piece a kit together especially if you pick all the high quality stuff.
btw: how is your H22 built?
Old Mar 19, 2002 | 09:18 AM
KS-R's Avatar
How much did it cost to get it built? Did you re-sleeve the block? Especially with the previous threads about the nikelsile coating on the cylinder walls, I'm very curious if you addressed that issue. Thanks.
[Modified by KS-R, 10:19 AM 3/19/2002]
Old Mar 19, 2002 | 11:09 AM
apexii's Avatar
Default Re: FS: Going turbo on Built H22...need some advice (KS-R)
You must re-sleeve.
I'm guessing his motor is not built yet.
Old Mar 19, 2002 | 07:51 PM
Default Re: FS: Going turbo on Built H22...need some advice (apexii)
you can ask my friend who goes on this post about it, he actually still has the motor.
this is the specs i know so far:
Micropolish crank
Crower rods
araias 9:1 pistons
sleeved iron ductiles (iron sleeved bottom end, you have to do this if you put in aftermarket parts)
port and polish head
stainless steel valves
stiffer spring
jg throttlebody
3 degree angle valve job
japan4racing
Aug 25, 2008 07:17 PM
accord97excoup
Aug 9, 2007 05:28 PM
Tippyman
10
May 21, 2006 06:29 PM
Team 4R
Jan 29, 2004 11:31 PM
djmano
Jun 20, 2002 04:26 PM
