89 Civic leaking Coolant
Old Jan 1, 2006 | 01:38 AM
mckim's Avatar
Default 89 Civic leaking Coolant
I have 89 civic with 210K miles on it. I've a leaking problem of coolant.
Each morning I check under the hood, I see the about inch diameter of coolant drops under the car. I know that drops is a coolant. I'm losing about one cup
of coolant every month. do I have a leaking on waterpump? or the leaking could
be from seeping hole on waterpump? I have flushed the radiator 6 month ago.
I used the chemical stuff to flush out all the old coolant. Since then I got the
leaking problem. Shall I fix this right away?
Old Jan 2, 2006 | 08:04 PM
si 1's Avatar
Default Re: 89 Civic leaking Coolant (mckim)
You can get this stuff to put in your radiator it is a dye that you use a blacklight and run the car and shut it of then take the black light and see where its coming out of
Old Jan 2, 2006 | 08:47 PM
MidoriBG96's Avatar
Default Re: 89 Civic leaking Coolant (si 1)
can you give an idea of which side its coming from(belt side, tranny side, front or rear of the motor) that would help.
DelSol-B18
27
Jun 27, 2013 04:16 PM
dizzi
11
Sep 1, 2012 12:43 PM
integranewb
May 7, 2007 02:12 PM
TEGGRY
Jun 12, 2006 12:33 PM
honda_coupe
Jan 24, 2006 03:10 PM
