LSvtec idle problem
Old Dec 31, 2005 | 06:26 PM
LsVtakYO's Avatar
Default LSvtec idle problem
ok i have a 1996 civic Ex with a lsvtec swap.im am running a jumper with a stock p28.the car will not idle or run under 3k rpm.if i start the car and hold the gas it will run fine over 3k rpm.anyone has any suggestions thanks
-jay
Old Dec 31, 2005 | 06:37 PM
lsvtecracer's Avatar
Default Re: LSvtec idle problem (LsVtakYO)
Are you using an aftermarket chip or stock ecu?? Did you check the iac valve to make sure it was clean with no carbon deposit? It sound like the iac is not working correctly.
Old Dec 31, 2005 | 06:39 PM
LsVtakYO's Avatar
new Iac and stock p28
Old Dec 31, 2005 | 08:06 PM
ek-to-tha-max's Avatar
Default Re: (LsVtakYO)
check your throttle cable, im pretty sure you made it too tight.
Old Dec 31, 2005 | 08:20 PM
ej1_lsvtec's Avatar
check you cable like he said or check the vacuum hoses i had the same problem a week ago and the hose on the intake manifold closest to the driver side on the back of the manifold wasent hooked up. it goes from the heater core to the manifold.
Old Dec 31, 2005 | 09:49 PM
LsVtakYO's Avatar
Default Re: LSvtec idle problem (ej1_lsvtec)
throttle cable is good and i hooked up the vaccum hose on the back and still the same problem.when i start the car is sputters and misses real bad but if i rev it over 3k its ok.its very weird
Old Jan 2, 2006 | 08:13 PM
OMG B16's Avatar
MAP.
Old Jan 2, 2006 | 09:59 PM
TurboCoop's Avatar
Default Re: (Sick00SiCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe &raquo;</TD></TR><TR><TD CLASS="quote">MAP.</TD></TR></TABLE>
Old Jan 2, 2006 | 11:56 PM
OMG B16's Avatar
Default Re: (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">Quote</TD></TR></TABLE>
Got any 1/4mile times with that coupe of yours?
Old Jan 4, 2006 | 11:03 AM
99lsvtecauto's Avatar
you can't run a stock p28 on an lsvtec you need to get the p28 reprogrammed
busha61067
Feb 13, 2010 09:00 AM
White GSR '01
Jul 17, 2005 11:17 PM
douboi
13
Oct 15, 2004 09:16 PM
89b16hf
Feb 17, 2004 07:31 PM
crx-si
10
Jan 30, 2003 07:26 AM
