EPROM CHIP FLASHING?
Every time I get one flashed it is flashed with a vtech pressure switch, I NEED THE V TECH SWITCH DISABLED.
JDM SPEC type R
2.0 Liter 11.5 to 1 compression
440 injectors
buddy club spec 4 cams
Thanks..
JDM SPEC type R
440 injectors
Thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">all u have to do is splice the vtec pressure switch wire into the vtec solenoid wire.
at the ecu.</TD></TR></TABLE>
explain????
explain????
he means run a jumper wire btwn pin D6 and pin A4 on the ECU. the pinout diagrams are here http://www.autoserve.8m.com/ECU_connector.html
there is a write up in PGMFI about this too
here http://forum.pgmfi.org/viewtop...p+fix
JSPECSIR
Oct 7, 2008 06:56 PM
B_CRUZ!
22
May 13, 2004 09:00 PM
