How do i stop my locks from freezing up?
Old Dec 31, 2005 | 09:34 AM
noltofan69's Avatar
Default How do i stop my locks from freezing up?
Hi i have a frequent problem, i live in Canada and every day my locks are frozen!!!! when i try to open it it feels like i am going to break the lock i use all those lock deicer products and most of them work until i need to unlock them again.. i no it happens to people sumtimes but for me its all the time, should i replace the locks? please help thanks
Old Dec 31, 2005 | 09:37 AM
underb00steg6's Avatar
Default Re: How do i stop my locks from freezing up? (noltofan69)
just have them replaced
Old Dec 31, 2005 | 09:38 AM
sicones's Avatar
Default Re: How do i stop my locks from freezing up? (underb00steg6)
how would replacing the locks stop them from freezing???
Old Dec 31, 2005 | 09:42 AM
h23civic's Avatar
try spraying some wd-40 on the locks after you deice them. see if that doesn't help.
Old Dec 31, 2005 | 09:59 AM
philosofy1's Avatar
i would try some wd-40, also how worn out is your key? sometimes with a worn out key, not all the pins are pushed in having this frozen affect. had the same problem when i bought my civic, went to a lock smith and had 2 new key made.
Old Dec 31, 2005 | 10:30 AM
old man neri's Avatar
Default Re: (h23civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23civic &raquo;</TD></TR><TR><TD CLASS="quote">try spraying some wd-40 on the locks after you deice them. see if that doesn't help.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i would try some wd-40, </TD></TR></TABLE>
NO!
Graphite; get it, use it, and love it. Spray the **** out of your lock to make sure you get any water or dirt out.
You can get this stuff at any Crappy Tire.
Old Dec 31, 2005 | 11:02 AM
nocturnaldragon's Avatar
Default Re: (old man neri)
I agrea with you on this WD-40 evaporates after a while leaving just the alcohol which dwaws in more moister.
Get some of that graphite stuff, or I used a white lithium grease on mine.
Either case take them out clean them up real well and brease all the moving parts heavily and thouoly. then reassemble and you should be good to go. I did that to my passenger side lock that would bind up all the time and never lock unless you hit the button 3 times now it works better then the drivers side.
Old Dec 31, 2005 | 11:25 AM
Default Re: (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">
The problem with Lithium grease is that is gums up when it gets cold. When it is about -40 outside the stuff is pretty thick.
do what
10
Sep 20, 2007 02:41 PM
theeogflip
May 25, 2006 08:54 PM
oc_civic
10
Nov 23, 2005 10:37 AM
Beezle
Jan 15, 2005 02:52 AM
Bushwacker
Feb 20, 2004 09:43 AM
