P1457:Unable to pull vacuum from tank
I failed emissions a while back and still have not had time to fix the problem. At the testing center I got a P1457 code. I read the archived post and found out it can be a multitude of things related to the EVAP canister. However, I took the car to AutoZone so they can diagnose it there. The code there was the same but it read unable to pull vaccum from tank. Does anyone know what that means?
everyone’s going to say vacuum leak, I would check ALL of the hoses make sure there not torn and connected properly, and make sure the evap purge valve is functioning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge99hx »</TD></TR><TR><TD CLASS="quote">I failed emissions a while back and still have not had time to fix the problem. At the testing center I got a P1457 code.</TD></TR></TABLE>
Year and model? Some of em have known problems.
check yoru gas cap, that code is checking for leaks in the fuel system, if it cant pull vacuum it means theres a leak letting air in equalizing the pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX »</TD></TR><TR><TD CLASS="quote">if it cant pull vacuum it means theres a leak letting air in equalizing the pressure</TD></TR></TABLE>
Just what I was going to say!
teler86
12
Feb 20, 2007 01:46 PM
accordv6turbo!!!
Sep 19, 2005 02:27 PM
