b16a1 distributor
Old Mar 18, 2002 | 08:22 PM
Frcfedintegra's Avatar
Default b16a1 distributor
my distributor is on its way out. i was wondering if anyone has a new distributor or knows where i can get a brand new one. this is for the b16a1. thanks
Old Mar 18, 2002 | 08:42 PM
RexB16's Avatar
Default Re: b16a1 distributor (CivlizdSir)
bramd new one! ha, thats ******* hillarious! my friend you are SOL on that conquest. you could try to find someone selling a used one for sale, but with tha you are only buying time. fyi, older honda distributors just plain SUCK, so getting a 12 year old replacement may not be what you want to do. my advice is you go get a remaufactured one at autozone, it comes with a warranty so if it goes u are covered. you havr to modify it tho, in order for it to fit you have to cut the front post (the one that points toward the front of the car) it looks harder than it actually is. the case is aluminum, so a little hacksaw job and it will cut right thro.
Old Mar 18, 2002 | 09:17 PM
Jonathan_ED3's Avatar
Default Re: b16a1 distributor (RexB16)
what car would you order the remanufactured one from? i heard 90-93 Teg..
Old Mar 18, 2002 | 09:49 PM
big pete's Avatar
Default Re: b16a1 distributor (hot_EF)
the integ one wont fit unless you cut one of the legs off......you can get one at the same place you got your motor
Old Mar 18, 2002 | 09:53 PM
Blown90hatcH's Avatar
Also, the 92-93 electronics are different too.
Old Mar 18, 2002 | 10:18 PM
RexB16's Avatar
Default Re: b16a1 distributor (big pete)
hey genious, how about you go back and read the part where i already cover this. and for some reason i forogt to mention, you need a 90-91 integra dist. in 92 honda went to odb1 whixh will not work on your gen 1 b16.
Old Mar 18, 2002 | 11:42 PM
CRX-RX's Avatar
So how bout this???(just for future information) Can you get the housing of a 92-3 GSR and bolt it up to a B16A1 properly, and swap the internals of the JDM B16 distributor over to the new housing? Then as long as the bearings hold up, you keep replacing internals with LS dist. parts.
Old Mar 19, 2002 | 11:36 AM
RexB16's Avatar
Default Re: b16a1 distributor (CRX-RX)
i suppose that would work, but if you were going to that what not just use ur old dist case from the bee one six? but a warning to you, the screws that hold the case together are VERY brittle. i have tried take to old b16 distributors apart with no luck, screws broke apart. i guess i could have gotten them apart, but i just didnt care.
Old Mar 19, 2002 | 11:40 AM
turbo_ef9's Avatar
i got one. i don't know the condition of it.. i got it off my b16 motor.. i decided to go obd1 everything so if you want it buy at your own risk.... i got the motor and just took it off so your call... lemme know if you want it..
Old Mar 19, 2002 | 12:41 PM
CRX-RX's Avatar
Default Re: b16a1 distributor (b16_ef)
I'm just asking if the bearings ever happened to go bad in the case.
Old Mar 19, 2002 | 12:47 PM
RexB16's Avatar
yes, after about 10 years or so they do. but they sell rebuild kits. kind of a difficult thing to do tho.
Old Mar 19, 2002 | 08:05 PM
where could i send my distributor to have it rebuilt? it needs new bearings. and do you know aprox. how much this would cost? thanks again
Old Mar 19, 2002 | 09:53 PM
RexB16's Avatar
hmm, to be honest i really wouldn't know where to send it off. i would just go get the kit at bap.
DarkFlame
Jan 16, 2014 11:17 AM
Tuneman1984
13
Jun 12, 2013 01:53 PM
The_Head
Jan 11, 2012 07:58 PM
WVhump
Acura TL, RL & ZDX
Mar 28, 2007 10:30 PM
CWTegRNo.160
Jan 5, 2004 01:14 PM
