manual swap: pictures of welding necessary for shifter?
Old Dec 30, 2005 | 01:37 PM
fujiwara takumi's Avatar
Default manual swap: pictures of welding necessary for shifter?
i hope that explains it. Can someone show me their shift lever? i understand it needs to be welded at the chassis, id like to see what needs to be done.
Old Dec 30, 2005 | 01:45 PM
jlicrx's Avatar
Default Re: manual swap: pictures of welding necessary for shifter? (fujiwara takumi)
are you doing auto to manual swap?
Old Dec 30, 2005 | 01:46 PM
yes sir
Old Dec 30, 2005 | 01:54 PM
jlicrx's Avatar
Default Re: (fujiwara takumi)
i don't think you need to weld it - i believe you just need to drill 2 holes and bolt it down, just like it comes from the factory
Old Dec 30, 2005 | 02:01 PM
RCautoworks's Avatar
You don't need to weld anything.
Old Dec 30, 2005 | 02:04 PM
hmm, well i got an auto now. if i just go get the shifter i need the upper and lower plates right? im missing something.
Old Dec 30, 2005 | 02:19 PM
B series connects to the trans a little differently, basically just a bolt no bracket. If your doing a swap, if not don't worry.
Old Dec 30, 2005 | 02:23 PM
Default Re: (90blackcrx)
ah ok, i c now. On my 99 things were ?different? *or it was 5 years ago and my mind is going*, i think i understand now. I got a PILE of linkages when i got my swap, i didnt realize it was setup this way. thanks for the pic, that helps a lot.
Old Dec 30, 2005 | 02:27 PM
On b series transmission there is no #17, the bolt just hooks right to the trans.
Mr_Midori
13
Mar 3, 2008 01:20 PM
omgwtfbbqcrx
Apr 24, 2006 08:16 AM
consolidatedbord
Jan 28, 2005 02:08 PM
