camber kit for ek
i have a skunk2 camber kit that i am ready to install on my ek coupe. only problem is im not sure where it is supposed to be set at. does it have to be set by a professional shop with some special tools or anything like that? thanks in advance.
You should just eyeball it when you install it, and then take it straight to an alignment shop to have them do it. Chances are you screwed up all the other specs as well, so they will get it all set up for you.
alien wrenchs should work, just set them the same offf the car using a tape measure to make sure they are equal,
i also put mine on and then took it for an alignmet and had them do it also.
like no tire wear
like no tire wear
Derek Perez
40
Jun 23, 2017 04:42 AM
