Oil Pan Gasket, to use sealant or not?
Old Dec 30, 2005 | 08:52 AM
jadugartir's Avatar
Default Oil Pan Gasket, to use sealant or not?
I searched and came up with mixed results. This group says use sealant on the corners, this other group says none at all, I want somebody who has done this before and done it right to tell me. Do i need to put any kind of sealant when replacing this gasket? and if so, what kind works best?
Old Dec 30, 2005 | 08:58 AM
snatch's Avatar
Default Re: Oil Pan Gasket, to use sealant or not? (jadugartir)
Helms manual says to use liquid gasket in the 4 corners.
Old Dec 30, 2005 | 09:07 AM
LShatchie's Avatar
Default Re: Oil Pan Gasket, to use sealant or not? (******)
dont use the sealant, everytime I have the oil pan has leaked... just make sure both surfaces are clean and torque to specs
Old Dec 30, 2005 | 09:10 AM
ralphie14's Avatar
Default Re: Oil Pan Gasket, to use sealant or not? (LShatchie)
When I put my Moroso pan on I put a small bead of sealant down the middle of the entire gasket and after 3K+ miles it has not leaked a drop. It may not be needed but why wouldn't you do it just for a little extra protection.
Old Dec 30, 2005 | 09:12 AM
JDM-EJ1's Avatar
Default Re: Oil Pan Gasket, to use sealant or not? (ralphie14)
When I installed my oil pan, I used Hondabond to seal it. Never had any problems with mine.
wob's Avatar
wob
never had any problem using sealant.. i use it all the time
Old Dec 30, 2005 | 01:47 PM
turbotime's Avatar
yeah mine has sealant on it and now appears to be leaking
Old Dec 30, 2005 | 02:09 PM
LiL EG's Avatar
i follwed helms was changed 2k miles ago..no drip/leak
j4s0n1337
Nov 24, 2011 08:31 PM
miro_gt
Jun 24, 2007 08:02 AM
oneiro
Apr 9, 2007 08:13 AM
LAKER HATER
Aug 26, 2004 02:57 PM
wickedxboi
Feb 28, 2003 11:50 PM
