does your rm-01a scrape?
just installed my rm-01a, and i noticed the rear resonator hangs pretty low, as in it is now the lowest point on the car. do you ever hit yours on speedbumps and such?
Dammit, I did not think you were lurking in the back ground... I was going to post this...
a good person to ask would be Opie, he had that exhaust on for a while in NYC.
Word, I did, never had any problem. In fact, the exhaust fits so well that it comes with that heat wrap for your rear brake line because it sits so close to it and the body of the caR.
I should have never sold her
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie »</TD></TR><TR><TD CLASS="quote">
too late now
too late now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Dammit, I did not think you were lurking in the back ground... I was going to post this...
a good person to ask would be Opie, he had that exhaust on for a while in NYC.</TD></TR></TABLE>
I had it for quite a bit longer than he had it around NYC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">I had it for quite a bit longer than he had it around NYC.
ahem, got you both beat
</TD></TR></TABLE>ahem, got you both beat
Chalk another one up for not rubbing with an RM01A on an ITR or EG hatch. (Minus when I was running open header and missing a hanger for the ITR...THEN it scraped...
on me)
on me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">ahem, got you both beat
You never drive so you don't count.
</TD></TR></TABLE>You never drive so you don't count.
x2
</TD></TR></TABLE>x2
I had to cut the 4 inches as many have done, but not did not adjust the angle of the B-pipe when the ends were welded back together. I have no rub/scrap issues at the moment...but if i were to change my suspension and drop the car a couple inches that would most likely be a concern.
I did have to find a larger hanger for the back section of the B-pipe, as it was causing the exhaust to hit the frame when the car would jerk enough (starting and stopping usually). I think that can be blamed on the readjustment issues i didn't make though.
Excellent choice of exhaust BTW
spoonracer84eg
47
May 4, 2006 12:13 PM
Takumi Fujiwara
Jan 25, 2006 12:56 PM
