obdI & obdII
Old Dec 29, 2005 | 09:19 PM
dayaftertomorrow's Avatar
Default obdI & obdII
What is the different between the engine of the obdI & obdII? ECU of obd I and OBDII? Execpt obd II is more environmental, why engine of obd I & obd II produce the same HP? Will it hurt the engine of Obd II if I use an OBD I ECU with conversion harness? Need some answer. THanks
Old Dec 29, 2005 | 09:33 PM
suzawa94's Avatar
Default Re: obdI & obdII (dayaftertomorrow)
well, first of all OBDII was designed with more sensors to monitor the excess gases that pollute and to better contain them. not to mention that OBDII has the diagnostic port to hook up a scan tool. OBDI was a more basic type of ecu which would flash codes and also had less sensors to read. i'm not sure why they produce the same power. about the OBDII to OBDI conv i have no idea
Old Dec 29, 2005 | 10:15 PM
iH8RICERZ's Avatar
no it will not hurt your car to run an obd1 ecu on a obd2 motor. MANY people who have built obd2 motors will typically convert to an obd1 ecu mainly for tuning purposes. Converting to obd1 offers more options when it comes to tuning, ie. uberdata/hondata/crome/etc.
Old Dec 29, 2005 | 10:24 PM
Default Re: obdI & obdII (iH8RICERZ)
I have a 2001 gsr with AEM cold air, old spoon header, spoon TB, mugen twin loop exhaust. I just bought a OBDI ecu. It is for daily driving and sometime on a track once for a while. Should I go hondata s300 or should I get one of the custom chip from you? Need some suggestion. THanks
Iceman05
Jun 7, 2004 04:52 AM
LpBoy2004
Feb 13, 2004 08:25 PM
kool168
Nov 26, 2003 05:13 AM
xstalkrx
Oct 5, 2003 09:52 AM
