Who here has ever used a Field SFC-VTEC controller?
does anyone know whether or not they make a harness for the JDM 92-96 computer? what should the default settings be set at? of course i will set the dipswitches to eliminate the speed limiter....
I'm running a Fields SFC-VTEC Controller on my H22A4 setup. The motors OBD-2 but its setup to be OBD-1 so is the VTEC controller. I have my VTEC X-Over set to 5000 and I like it right there. But to get true and the best results would be to dyno it and set it on the dyno accordingly. Check out inlinefour.com I believe they have the harness you need.
to tell you the truth there is no big difference, I personally wouldn't buy the VTEC controller, just get Hondata which is the **** and it also has VTEC control option also. I think these things r really just for appearance purposes only.
i bought it simply to eliminate the speed limiter. i won't be tearing the engine down until next winter. but i wasn't sure whether or not the 97-up harness would be compatible with the jdm 92-96 platform (and plug hookup)
