CEL on after straight pipe install
Old Mar 18, 2002 | 05:47 PM
EGhatched's Avatar
Default CEL on after straight pipe install
hey guys, i just put on a straight pipe on my 98 civic ex, it made my car sound like *** by the way, but anyway. It runs fine but just today i was doing about 80 on the interstate and the check engine light came on.? Any idea why this could be? How do i check the ecu for the error code or whatever? thanks
Old Mar 18, 2002 | 06:15 PM
Plan B's Avatar
Default Re: CEL on after straight pipe install (redcivicex2424)
Okay, there's really no reason to check your codes because you have now removed the catalytic converter and you are blowing the same junk through both sensors, which makes your ECU very unhappy. My suggestion, either change over to an obd1 set-up where you don't use the second sensor, or have a new cat and o2 sensor bung welded up, then you should be straight, although, it will probably still sound like ***.
btw, under your passenger side dash there is a little plug you can pull out, it's probably stuck in a little rubber holder, just pull it out and take a piece of wire, strip it a little on both ends and stick both ends in the two terminals on the plug, BAM! you just jumped the ECU, turn the ignition on and the cel will flash, count it and then you will know what is wrong.
Hope that helps.
Old Mar 18, 2002 | 06:16 PM
DR. ON POINT's Avatar
Banned
if the 02 sensor is not in the cat and just hanging wrap it in aluminum foil and ur good to go....**** CEL's
Old Mar 18, 2002 | 06:31 PM
Plan B's Avatar
Default Re: CEL on after straight pipe install (On Point EK)
oh yeah, forgot about that.
Old Mar 18, 2002 | 06:40 PM
EGhatched's Avatar
when the CEL is on, doesnt VTEC not work though?
Old Mar 19, 2002 | 05:35 AM
Banned
depending on which code is flashing
ITRBOY1433
Honda S2000
12
Oct 20, 2010 07:50 AM
h22xcivic
Apr 27, 2006 07:51 PM
JDubya
Dec 13, 2002 06:49 PM
99CivicSi
Mar 31, 2002 08:09 PM
AzianAvenger
Aug 6, 2001 06:46 PM
