steering rack or inner tie rod ends?
Old Dec 29, 2005 | 06:36 PM
si0385.'s Avatar
Default steering rack or inner tie rod ends?
its a 90 crx si ... no p/s of corse...i just got it up and running earlier today but while im driving down the road the steering is realy squirly... when its not running and you listen carefully you can hear a nocking when you turn the wheel back and forth and you can feel it if you put your hand on the rims... i had my father turn the wheel while i felt each tie rod on each side of the car and they both knocked the outer tie rods were not moving at all....
my question is... is there a way to tell if its the inner tie rod ends that are going bad or it it the steering rack its self...
Old Dec 29, 2005 | 06:39 PM
skr33t_rac3r's Avatar
check the sterring rack end bushing
i found out it is a common problem on crxs and i had to replace mine too so itll prolly be ur best bet
Old Dec 29, 2005 | 06:42 PM
si0385.'s Avatar
Default Re: (skr33t_rac3r)
i was looking under there earlier and on the passenger side its got one poly-urethane bushing lol i didint check out the driver side bushing but it wasint bright red so idk if they replaced both thats the only reason i suspected inner tie rod ends or the rack its self
Old Dec 29, 2005 | 07:41 PM
higgunscrx's Avatar
rack end bushing is located inside the end of the steering rack, not accessable unless you remove the inner tie rods. you can remove the inner and outers together therefore you wont mess up you alignment. do a seach under rack end bushing, theres a few posts about it
edit heres the post https://honda-tech.com/zerothread?id=1419011
Old Dec 29, 2005 | 09:38 PM
Tyson's Avatar
Default Re: steering rack or inner tie rod ends? (jaydeum4lyfe)
im pretty sure your rack end bushing needs replacement (the one INSIDE the passenger side boot), and maybe your outer tie rods, both sides, need replacement. it just takes a simple check. your inner tie rod probably doesnt need to be replaced as likely as the outer, but its possible. most definately the steering rack end bushing needs replacement.
Old Dec 30, 2005 | 04:25 AM
Cory man's Avatar
Default Re: steering rack or inner tie rod ends? (Tyson)
Even if it is just the inner tie rod I would replace the outer as well while you have it apart. Check the rack bolts that tie into the subframe as well. Make sure and get an alignment once all your suspension work is done.
relentlesstech
10
Feb 12, 2025 09:24 PM
ra64
Sep 15, 2014 06:48 PM
keith1993may
Mar 7, 2013 02:34 PM
vinuneuro
Suspension & Brakes
Jan 5, 2009 03:49 PM
qazaq
Apr 20, 2008 03:26 PM
