9.5:1 pistons in B16 engine is what in B18C5 engine?
Old Mar 18, 2002 | 02:56 PM
BlackGSR's Avatar
Default 9.5:1 pistons in B16 engine is what in B18C5 engine?
What's the compression of a 9.5:1 piston in a B16 engine in a B18C5 engine (GSR bottom end + ITR head)?
Thanks.
Old Mar 18, 2002 | 03:00 PM
R you serious's Avatar
Default Re: 9.5:1 pistons in B16 engine is what in B18C5 engine? (BlackGSR)
clarify?? is it just me or does that make no sense?
Old Mar 18, 2002 | 03:01 PM
BlackGSR's Avatar
Default Re: 9.5:1 pistons in B16 engine is what in B18C5 engine? (R you serious)
If a take a 9.5:1 piston out of a B16 engine ... and put that piston in a Type-R motor ... what would the compression be in the Type-R motor?
Old Mar 18, 2002 | 03:02 PM
TurboITR's Avatar
9.5
[Modified by TurboITR, 7:02 PM 3/18/2002]
Old Mar 18, 2002 | 03:04 PM
BlackGSR's Avatar
Default Re: 9.5:1 pistons in B16 engine is what in B18C5 engine? (TurboITR)
9.5
Same compression in ITR motor? Doesn't the B18 motors have a longer stroke so the compression numbers will be different?
Anyone else?
Old Mar 18, 2002 | 03:07 PM
RyanR's Avatar
Just an estimate but I'd say around 11.1:1. If you think about it, a CTR engine with 1.6L stroke is 10.8:1 and when you take that piston and install it in a Type R engine it's ~12.3:1, which is a 1.5:1 increase.
[Modified by RyanR, 4:08 PM 3/18/2002]
Old Mar 18, 2002 | 03:09 PM
BlackGSR's Avatar
Default Re: 9.5:1 pistons in B16 engine is what in B18C5 engine? (RyanR)
Well, just called JE up ... around 10.5'ish in ITR motor.
Damn ... too high for turbo
Old Mar 18, 2002 | 04:04 PM
R-1303's Avatar
way to high..unless u plain to get a wastegate set at 2 psi
Old Mar 18, 2002 | 04:06 PM
Reid's Avatar
Global Moderator
Why?
Old Mar 18, 2002 | 04:54 PM
Type-ARR's Avatar
Default Re: 9.5:1 pistons in B16 engine is what in B18C5 engine? (R-1303)
why would you say that?
djustice_tn
Jul 11, 2009 03:05 AM
Brent1
10
Dec 11, 2005 07:38 AM
Dodger2940
Aug 25, 2002 12:10 PM
96tegsr
Jan 19, 2002 09:17 AM
