Possible power lost
A while back i experience a lost in power. Pretty much tried everything to figure it out. Compression test, fuel pressure, ignition, and couple of other things. One thing that keept me curious is that a mechanic had a laser temperature reader. He pointed that headers 2-4 are the same temp but header tube 1 is 50 degrees lower than the rest. Those any body know what could be causing this. Could it be a faulty injector? would this be the cause of my slower accelaration.
Come on has anybody ever had a problem with their gsr with i/h/e were it started to performed slower accelation. example struggle to hit 8000 rpm in fourth gear straight away or worse on up hill highway.
its gonna be one hell of a clogged injector since took out and tried cleaning them. I was running rich at the time. check engine light came on for the o2 sensor wire that got loose. Would be surprised if it fried something.
InvaderTrax
May 4, 2008 01:57 PM
