do i use b16 or b18 header??
Old Dec 28, 2005 | 12:51 AM
yoursupahero09's Avatar
Default do i use b16 or b18 header??
i have swapped in a jdm b18c gsr into my del sol. if i were to buy a header would i buy a b16 or b18 header? im asking for clearance issues?? what do you guys use on your swapped cars? the car was orginally the b16 vtec model.
Old Dec 28, 2005 | 01:36 AM
Fugun's Avatar
Default Re: do i use b16 or b18 header?? (yoursupahero09)
use the b18 header.. because i beleive the block is taller...
im currently running a b16.. with b18 headers that **** hangs low, but my friend with a gsr, tried to use b16 headers and AIYA it didnt fit...
toodles
Old Dec 28, 2005 | 01:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: do i use b16 or b18 header?? (Fugun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fugun &raquo;</TD></TR><TR><TD CLASS="quote">use the b18 header.. because i beleive the block is taller...
toodles</TD></TR></TABLE>
Yea. You can force a B16 header to fit on a B18, but its a real pain in the ***, as the block is a few cm's taller.
Old Jan 16, 2006 | 11:52 AM
jdm_slo's Avatar
Default Re: do i use b16 or b18 header?? (JDM_Ej)
the b18 or b16 header will work fine in my del sol i had a b18
Old Jan 16, 2006 | 12:08 PM
x93coupex's Avatar
Default Re: do i use b16 or b18 header?? (jdm_slo)
se a b18 the you gotta remember you dont need not extra heat to your oil
MaGoodc2
May 3, 2006 02:25 PM
the.hamburglar
Feb 12, 2006 10:55 AM
BigZ88
Dec 7, 2003 12:29 AM
IVI
Oct 26, 2003 07:10 AM
