Wiring Question. 92 EX vs 93 CX main wiring help please
Old Dec 27, 2005 | 07:56 PM
CRXified's Avatar
Default Wiring Question. 92 EX vs 93 CX main wiring help please
ok i just need to know if the main harness from the 92 Si/EX would be the same as the 93 CX/DX or would there be some wires switched around in any of the pins.
me and my friend are thinking they might have some different pin locations on the plugs in the engine bay.
the reason is that i have a B16 with a CX engine harness on it and putting it into a 92 SI/EX shell. we were having a problem when we gave it gas it would die out and my friend thinks the TPS sensor wires might be oppisite on the SI/EX main harness compared to the CX harness and he wants to switch them to see if it makes a difference.
i dont think there would be a difference, but because the 92 was the car that came prewired for vtec and such, i just wanted to make sure there wasnt a difference
JDMlyfestyle can chime in here and help
Old Dec 27, 2005 | 08:37 PM
fmrprojects's Avatar
Default Re: Wiring Question. 92 EX vs 93 CX main wiring help please (CRXified)
you should be coo. If the 93 cx runs a 4-wire o2 sensor then you should be okay to swap it in
Old Dec 27, 2005 | 11:52 PM
CRXified's Avatar
Default Re: Wiring Question. 92 EX vs 93 CX main wiring help please (fmrprojects)
eyah it does, but i was wondering about the main harness being teh same
does the 92 EX/SI run a 4 wire O2?
Old Dec 28, 2005 | 01:37 AM
CRXified's Avatar
bump for morning
Old Dec 28, 2005 | 01:56 AM
wob's Avatar
wob
its the same
Old Dec 28, 2005 | 01:58 AM
wob's Avatar
wob
Default Re: Wiring Question. 92 EX vs 93 CX main wiring help please (wob)
and yes its a 4 wire
Old Dec 28, 2005 | 03:17 AM
CRXified's Avatar
thanks man
i see u need tie rod ends for a civic, pm sent
Old Dec 28, 2005 | 06:08 AM
Solo1B16Hatch's Avatar
does the 92 EX/SI run a 4 wire O2?[/QUOTE]
I would check this. My 92 hatch was a 1 wire o2 sensor, had to rewire it. An easy, but time consuming way would be to make a diagram of your plugs and trace where the wire go one by one and compare to your friends car.
Something else that is possible. When you swapped the motor into the new shell, had the new shell been sitting for a while? If so, I would drain the gas tank of the old gas, there is a possibility of water in the tank which would make the car run terrible or not at all depending on how much water is in the tank. Have you replaced the fuel filter? Or there could have been trash in the exposed rubber fuel hose that comes out from under the firewall and connects to the engine.
There are lots of other possibities. Did you use the same ecu as before? Adjustable FPR? Hopefully you can get it running properly
Old Dec 28, 2005 | 08:49 AM
wob's Avatar
wob
Default Re: Wiring Question. 92 EX vs 93 CX main wiring help please (Solo1B16Hatch)
the d16z6 uses a 4wire one wire for the cx and 5 wire for the vx...
anyway, pm returned gimmie a good deal
Modified by wob at 1:45 PM 12/28/2005
Old Dec 28, 2005 | 11:24 AM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob &raquo;</TD></TR><TR><TD CLASS="quote">the d16z6 uses a 4wire one wire for the cx and 5 wire for the dx...
anyway, pm returned gimmie a good deal</TD></TR></TABLE>
DX is 4 wire, VX is 5 wire
Old Dec 28, 2005 | 12:44 PM
wob's Avatar
wob
Default Re: Wiring Question. 92 EX vs 93 CX main wiring help please (Timmay)
oops, typo.. edited
Old Dec 28, 2005 | 07:53 PM
CRXified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo1B16Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
There are lots of other possibities. Did you use the same ecu as before? Adjustable FPR? Hopefully you can get it running properly</TD></TR></TABLE>
yea thanks we got it running right today, in the 1st 10 mins lol
the tank had a slow leak around the drain plug cause the buddy i got it from didnt replace the crush washer and re-used it and it didnt seal. when we put the motor in it was sputtering and **** and when we touched the gas it would bog. we looked at teh gas gauge today before we put gas in and it was below E
bought $5 of supreme and put it in, started right up no codes and ran real nice
i just gotta replace the crush washer on the drain plug and hope it seals, if not i got a tank lined up for it.
thanks for all your help and heres a pic or 2 of the shell i got for $1000 CDN (flame away on the CF hood, im not fond of it, but he didnt have a stock 1)
typical honda rust here in canada, im replacing rear 1/4s next year
the day we did the swap, took 3 hrs total lol
thanks for the help guys, enjoy the pix and tell me what u think
Old Dec 29, 2005 | 08:18 AM
Glad to hear you got it running and glad I could be of assistance. Good luck with all other mods in the future
Old Dec 29, 2005 | 07:50 PM
CRXified's Avatar
thanks an ill be waiting for springs
Old Dec 30, 2005 | 06:00 AM
You need springs?
I have a virtually new set of Tein's I am about to get rid of for $80 (they have maybe 100 miles on them.
I am also trying to decide on whether or not to sell my ground controls.... not sure yet
Old Jan 2, 2006 | 11:14 AM
CRXified's Avatar
whats the drop on the tiens and do u have the part #? i may be interested if u ship to canada
chevmaro
11
Jul 11, 2011 09:23 PM
egsleepercivic
13
May 4, 2008 10:12 PM
wernhersey
Oct 13, 2006 12:48 PM
itr0032
Nov 20, 2001 04:31 PM
itr0032
Jul 9, 2001 08:06 AM
