bend lcas
Old Dec 27, 2005 | 07:44 PM
DB1_559's Avatar
Default bend lcas
ok i think my rear lca is bend how can i tell or that other peice connected to the brake. cause when i hit a bump its like my rear end move left to right like a dead shock will and one more question i bend my raditor support bad on the buttom will it affect my handling. last one if i get strut bars will it help my handling thanks
Old Dec 27, 2005 | 08:42 PM
fmrprojects's Avatar
Default Re: bend lcas (jdmboi86)
If you cant drive it slammed ,then raise the car up or get a better suspension. your bushings could be worn out, and the radiator support wont affect it, just looks ugly. and struts bars help
Old Dec 27, 2005 | 10:06 PM
underb00steg6's Avatar
just raise the car if its too low ......
Old Dec 27, 2005 | 10:07 PM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">If you cant drive it slammed ,then raise the car up or get a better suspension. your bushings could be worn out, and the radiator support wont affect it, just looks ugly. and struts bars help</TD></TR></TABLE>
Mostly good, but what makes you think it's slammed? A bent LCA will affect handling a lot. The only way to tell if it is bent is to raise the car and compare it to the other side or take it off and compare it to a brand new one.
-Shane
Old Dec 28, 2005 | 06:54 PM
DB1_559's Avatar
it not slammed i bought it like that the rear wheel lend in i dont want to buy something i dont need will a rear alignment help
Old Dec 28, 2005 | 07:04 PM
littleredcivic's Avatar
do the measurements. in the back of the helms, there are measurement points you can measure from and determine if something is not right. there are many things that can make your car do what it is doing.
Old Dec 30, 2005 | 08:56 AM
DB1_559's Avatar
ok i checked and see that the trailing arm bushing is gone/tored is that the prob
Old Dec 30, 2005 | 09:02 AM
common. get the prothane replacement, it is much better than the energy bushing. if you want to go gangster, get the spherical ball, but its very noisy and harsh.
blackakkord
Sep 11, 2008 10:44 AM
5lugSlug
Jul 24, 2005 04:22 PM
95srv
Apr 23, 2004 07:32 AM
ITR.#1446
Nov 8, 2003 07:24 AM
ex voto
Aug 22, 2003 10:52 AM
