Bad axel? Read for more info.
Old Dec 27, 2005 | 01:43 PM
mikeunreal's Avatar
Default Bad axel? Read for more info.
Guys what are signs of a bad axel? My car is shaking a little bit and when i drive real slow, like 10 mph it kinda jerks back and fourth, and if i drive real slow it feels like i have a buble in my driver side tire, which is where the bad axel is. Sound like an axel issue? Can the axel completely go out and leave me stranded somewhere?
Mike
Old Dec 27, 2005 | 02:05 PM
coquitlamEG's Avatar
Default Re: Bad axel? Read for more info. (mikeunreal)
yup, a bad cv joint can definatly leave you stranded. It's happened to me 3 times. What you described sounds like it could be your axle going bad. Have you taken your front wheels off any time lately? If so, i'd check to make sure the lug nuts are nice and tight. A loose wheel could make your car jerk back and forth like that too.
Old Dec 27, 2005 | 02:07 PM
mikeunreal's Avatar
Default Re: Bad axel? Read for more info. (coquitlamEG)
Ya the wheel is fine, beacuse it did this when i had my other set of wheels. My boot is split, and there was grease everywhere. I havn't gotten around to repairing it but i know its bad, and ive been told its bad. I just didnt know if the rocking back and fourth feeling was associated with my axel. Its not so bad at high speeds, but anthing below 40 makes it pretty evident that its there.
Mike
Old Dec 27, 2005 | 02:11 PM
yeah, i'd definatly change that axle as soon as you can. Once the boot rips, water gets inside and you lose all your grease.
Old Dec 27, 2005 | 02:36 PM
mikeunreal's Avatar
defnitally sound like an axel problem now that you know all this?
Mike
Old Dec 27, 2005 | 02:42 PM
turbotime's Avatar
axle, cheap, easy, fixed.
Old Dec 27, 2005 | 02:47 PM
mikeunreal's Avatar
Default Re: (turbotime)
Ya i just don't know how to fix it. Ive never done it before. A shop wont do it beacuse its not a stock axel used for that year and the motors in that year or some bullshit.
Mike
buzlink
11
Jun 23, 2009 02:42 PM
PatrickGSR94
Suspension & Brakes
19
Nov 29, 2008 06:09 AM
Nextelbuddy
Sep 11, 2003 06:59 PM
92hybridhhatch
Feb 22, 2003 03:59 PM
vteg
Dec 24, 2002 06:37 PM
