Code 19 GRRRR
Old Dec 27, 2005 | 08:16 AM
Kool305's Avatar
Default Code 19 GRRRR
Well yeah I've always had a code (since i did my swap)
i did an auto to manual swap and well I"ve had two codes
code 1 which is 02 sensor and got fixed...the other code is 19
which by JDMLIFESTYLE's code list is the "automatic Transmission lockup control valve" ...which makes sense...but how do i fix that? does anybody know?
I would appriciate it...
Old Dec 27, 2005 | 08:24 AM
littleredcivic's Avatar
change the ecu to a manual ecu. the ecu is trying to figure out why it can't control the A/T
Old Dec 27, 2005 | 08:36 AM
Kool305's Avatar
I have a chipped ECU P28 by kenji...and i still have that code. which by this point I'm guessing that it has to do with my dizzy since im already operating
the B series ...anyone has any info?
Old Dec 27, 2005 | 08:38 AM
does the chip eliminate the a/t functions and outputs??
Old Dec 27, 2005 | 08:45 AM
Kool305's Avatar
that i wouldnt know how to answer since i told kenji i had the swap done already when i purchased my ecu ... i didnt mention to him (the auto/manual swap) so that might be my problem..i would have to send the ECU back to him and have him do that hmm...thanks
any other possibilities...oh by the way i have two chips (performance Skunk2 stage two aggressive program from kenji) which when installed does not give me the code and i have a semi stock chip which im running now until i upgrade my cams...so hmm whats the deal with that?
Old Dec 27, 2005 | 10:28 AM
Kool305's Avatar
Default NO MORE CODES
disregard all this stuff...After further ANALysis i found out that i have
three codes (this time I read them by the book just as jdmlyfestyle explained to read cells) anyways i have Code 1 which is the 02 sensor.. I have code 10 which is the IAT and i also have code 9 which is the CYP...after my search i found all my answers and i'll get to clear them all out soon..thanks u all.
IIXtremeHansen
Dec 19, 2007 06:04 AM
rickturboteg
Oct 2, 2006 11:09 PM
turboex
Aug 29, 2003 06:57 AM
JDM CRX
Jul 22, 2002 04:54 AM
