Have i been worrying about nothing?
Old Dec 26, 2005 | 11:45 PM
wwang924's Avatar
Default Have i been worrying about nothing?
Hello again, haven't posted in a while. Last time i was on i was asking questions about putting an Ls in my ek hb. Well i've actually finally accumulated all the parts i needed to start working on it. One of my major concern was the wiring, but i just realized i have the LS wiring harness and of course the LS ECU. So does that mean I dont need to rewire anything? Were the rewiring issues for using the stock ek harness? Thanks guys, everyones been a big help.
*EDIT*
Another thing, if i use the LS cable does that mean there will be rewiring need somewhere else. If so, what will be the easiest way to wire this thing up, I have both harnesses available.
Old Dec 27, 2005 | 07:26 AM
96dxpower's Avatar
Default Re: Have i been worrying about nothing? (wwang924)
https://honda-tech.com/zerothread?id=550976
check out that thread. has some good info you might want to read. check out a couple posts down by B18C5-EH2.
Old Dec 28, 2005 | 01:13 AM
wwang924's Avatar
Default Re: Have i been worrying about nothing? (96dxpower)
good info but he seemed tobe refering to 94-01 tegs into 92-95 civics. I was doing some more seaching and acually found one thread that said i CANNOT use the inegra harnes... man i am so confused.
Old Dec 28, 2005 | 01:40 AM
wwang924's Avatar
bump b4 i sleep...
Old Dec 28, 2005 | 01:55 AM
wob's Avatar
wob
correct, u cannot use the integra harnass when doing a swap into an ek.. the integra harnass is 2 pc.. while the civic is 1... tho onlything good on that integra harness may only be some plugs and spare wire
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
OBD1 integra harness? Then use the engine harness. It will plug into to everything, then simply plug in the ECU and your done.
Old Dec 29, 2005 | 01:04 AM
wwang924's Avatar
Default Re: Have i been worrying about nothing? (JDM_Ej)
i think i need some picturesm there are SOOO many wires on that teg engine which is obdII also. for THE ENGINE harness, is that consisting of all the wires on the engine or just a specific portion? Is there anyone in the 626 area that will be able to help me out? Thanks.
Old Dec 29, 2005 | 05:23 PM
wwang924's Avatar
last bump, i think im going to go look for some local help =/
troycityssleeper09
Mar 22, 2009 09:24 PM
crowe
Feb 23, 2009 08:42 AM
chicows18
Apr 24, 2006 04:27 PM
cxhb
Sep 6, 2005 10:15 PM
Jlo96Hatch
Jul 19, 2004 10:03 AM
