Dc5-R Brembos on a Dc2-R?
Old Dec 26, 2005 | 05:18 PM
01-0720's Avatar
Default Dc5-R Brembos on a Dc2-R?
i searched and found info on brembo gt kits and others but not much about putting dc5r brembos on a dc2r
i was wondering if anybody has any expierence with this, or might know something about doing it, im talking about front and rear
i was wondering because this seems like a nice upgrade, because you could still run 16''s and maybe some 15''s instead of having to run 17''s like other brake kits
and you could still probally run regular rotors, ie inexpensive autozone rotors
thanks for any and all help you guys might give
Old Dec 26, 2005 | 05:33 PM
Shawn C's Avatar
In The Garage
do a mock-up jig of what the caliper bracket would need to be, find the correct diameter 5x114.3 rotor, and tell a machine shop what you need. let us know what you come up with
Old Dec 26, 2005 | 11:06 PM
tommymoose's Avatar
Default Re: (ShadyEH2)
I would very much like to see this done
Old Dec 26, 2005 | 11:38 PM
EK-Chris's Avatar
Default Re: (tommymoose)
I actually found a set (front & rear calipers & rotors) for $900. I would like to see if they fit on my Civic, but my car isnt here.
Old Dec 26, 2005 | 11:53 PM
B7AudiA4's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (01-0720)
wow, i never even though of an upgrade like this...
Old Dec 27, 2005 | 01:01 AM
92TypeR's Avatar
FSAE
https://honda-tech.com/zerothread?id=1225742
Old Dec 27, 2005 | 02:24 AM
an2ny888's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (92TypeR)
the TL and dc5 brembos are different, based on what i remember from that thread
Old Dec 27, 2005 | 02:28 AM
Bbasso's Avatar
Not to cause FIRE...
But Really... Is there a need other then BLING ?
:shakeshead:
Old Dec 27, 2005 | 03:41 AM
jdm_DC2R's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (Bbasso)
My gf bought some dc5R brembos for her 05 civic...so since i was storing her brakes in my garage, i tried to see how i could make them work on my 96dc2R....the only thing that worked is that the caliper bolted directly to where my caliper bracket would go...thats about it...besides that, u need a big caliper spacer, custom bracket, and BIGGER rims! not really worth it in my opinion...the caliper and rotor weigh a ton more than my factory.
Old Dec 27, 2005 | 06:03 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Not to cause FIRE...
:shakeshead: </TD></TR></TABLE>
No.
Not imo. But you know how those vary around here.
To each his own. I'll just have to keep a look out for all those under-used stock R calipers so I can scap em up at a cheap price and have loads of spares for parts and rebuilds.
Old Dec 27, 2005 | 06:05 AM
Bbasso's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
To each his own. I'll just have to keep a look out for all those under-used stock R calipers so I can scap em up at a cheap price and have loads of spares for parts and rebuilds. </TD></TR></TABLE>
Shussh Don't tell anyone our secret to getting cheap parts
Old Dec 27, 2005 | 09:22 AM
HapaHaole's Avatar
BTW the calipers on a DC5 are trailing and if you put them on an Integra, you have to make them leading. What is the difference you ask? Well, there is a thing called differential bores. The two sets of psitons are not the same size. This is to control pad taper. You will need to remove the plugs in the caliper and swap them with the bleed screws. I have no idea if you CAN actually do this on those calipers, because the holes may not be threaded the same. If you do not do this, your pad taper will be twice as bad as say using a normal stock ITR caliper because the differential bores will be opposite of what you need them to be.
Old Dec 27, 2005 | 09:28 AM
tommymoose's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (HapaHaole)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HapaHaole &raquo;</TD></TR><TR><TD CLASS="quote">BTW the calipers on a DC5 are trailing and if you put them on an Integra, you have to make them leading. What is the difference you ask? Well, there is a thing called differential bores. The two sets of psitons are not the same size. This is to control pad taper. You will need to remove the plugs in the caliper and swap them with the bleed screws. I have no idea if you CAN actually do this on those calipers, because the holes may not be threaded the same. If you do not do this, your pad taper will be twice as bad as say using a normal stock ITR caliper because the differential bores will be opposite of what you need them to be.
Thread Over.... although they would look pretty hot
Old Dec 27, 2005 | 01:36 PM
itr1244's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">Thread Over.... although they would look pretty hot </TD></TR></TABLE>
get one of those 20 dollar spoon caliper.. if u want it to LOOK hot.
Old Dec 27, 2005 | 01:59 PM
mugenracer's Avatar
Thread re-started...its been done. A member on ITR-DC2 forum in the UK done the conversion to his DC2 and his car is a JDM 96spec (4 lug)
Read here&gt;&gt;&gt; Click although its not very technical as he had a company called V-spec do it for him so theres no real info on whats needed...unfortunately!
Old Dec 27, 2005 | 02:11 PM
01-0720's Avatar
Default Re: (mugenracer)
lots of great information guys thanks alot
Old Dec 27, 2005 | 04:01 PM
an2ny888's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (jdm_DC2R)
jdmdc2r, it's not a good idea to use the tow hooks for the jack stands, both of mine bent when my mechanic had the same brilliant idea. i also read the brembo thread in the uk itr forum, unfortunately it doesn't provide any details on how the conversion was done
Old Dec 27, 2005 | 05:28 PM
jdm_DC2R's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">jdmdc2r, it's not a good idea to use the tow hooks for the jack stands, both of mine bent when my mechanic had the same brilliant idea. i also read the brembo thread in the uk itr forum, unfortunately it doesn't provide any details on how the conversion was done</TD></TR></TABLE>
Thanks for the heads up, i never thought bout them bending
Old Dec 27, 2005 | 07:47 PM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HapaHaole &raquo;</TD></TR><TR><TD CLASS="quote">BTW the calipers on a DC5 are trailing and if you put them on an Integra, you have to make them leading. What is the difference you ask? Well, there is a thing called differential bores. The two sets of psitons are not the same size. This is to control pad taper. You will need to remove the plugs in the caliper and swap them with the bleed screws. I have no idea if you CAN actually do this on those calipers, because the holes may not be threaded the same. If you do not do this, your pad taper will be twice as bad as say using a normal stock ITR caliper because the differential bores will be opposite of what you need them to be.</TD></TR></TABLE>
The solution is to swap calipers left-to-right and vice versa, same deal as with Legend calipers. Still some problems (like with the bleeder screw being upside down), but it apparently works.
Old Dec 27, 2005 | 07:53 PM
tommymoose's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
No wayyy, those are wayyy out of my budget... something like 80 dollars for the set...
BTW, " " closing a statement usually means somebody is kidding... douche
Old Dec 27, 2005 | 10:24 PM
migs's Avatar
Put the bleeder upside down. Brake fluid is by far more dense than air. You really think a tiny air bubble will push its way through the top of the caliper? Possible, but not likely if using the right tools.
Old Dec 28, 2005 | 02:08 PM
Hooch'n's Avatar
Default Re: Dc5-R Brembos on a Dc2-R? (migs)
Johnny Tran might be able to help you out
Nipsey Hussle
Mar 14, 2006 08:51 AM
Mrob91GS
Feb 17, 2005 08:31 PM
Solscud007
Dec 8, 2004 10:00 PM
Train
Dec 8, 2003 07:28 PM
Flux
Dec 2, 2002 07:54 PM
