timing off?
Old Dec 26, 2005 | 05:13 PM
gATOr65's Avatar
Default timing off?
so i just got my head milled, and as soon as i got it back i put it on the gsr. so before i sent it off i did do the timing and everything was at tdc. so when i got it back the head was washed and i noticed the timing was off on the head. so what should i do? any help would be appreciated.
Old Dec 26, 2005 | 05:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: timing off? (gATOr65)
What do you mean by "the timing was off on the head"?
Old Dec 26, 2005 | 05:36 PM
gATOr65's Avatar
Default Re: timing off? (Padawan)
the timing was set on the head, but when i got it back from the shop it was all off. i set the cams were at tdc, but i dont know what to do. how do i time the head with the block?
Old Dec 26, 2005 | 05:59 PM
Padawan's Avatar
Darth ModerVader
I'm still not totally clear what you mean. Are you referring to cam timing or ignition timing?
Old Dec 26, 2005 | 06:16 PM
gATOr65's Avatar
both
Old Dec 26, 2005 | 06:18 PM
gATOr65's Avatar
to time the cams do i put the marks on the cam gears facing each other (--)? and with the block at tdc would it run?
Old Dec 26, 2005 | 06:29 PM
Padawan's Avatar
Darth ModerVader
There should be three marks on the cam sprockets. One at 9:00, one at 12:00, and one at 3:00. The 12:00 marks should be pointing up, and the 3:00 mark on the exhaust sprocket should line up with the 9:00 mark on the intake sprocket. Since your head has been milled, the cam timing will be retarded slightly.
To set the ignition timing, you will need a timing light.
Old Dec 26, 2005 | 06:30 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
To set the ignition timing, you will need a timing light. </TD></TR></TABLE>
i'll let you borrow my timing gun. just pay for the shipping.
Old Dec 27, 2005 | 02:03 PM
gATOr65's Avatar
Default Re: timing off? (ernald711)
so i finally turned it on today. the only thing is that the rpms would just keep climbing. they went from3k to about5k so i shut it off. there is a lot of play in the belt. i made the belt tennsioner as tight as possible, but still alot of play. what can i do?
scUba-stEve
13
May 15, 2005 08:47 PM
vtecmike1
May 13, 2004 08:25 PM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
incognitoracerr
Apr 22, 2003 12:47 PM
Edwin
Jul 17, 2002 05:58 AM
