will suspension from ek fit a eg?
Old Dec 26, 2005 | 04:57 PM
jdm_eg94's Avatar
Default will suspension from ek fit a eg?
Do you guys know if the omni or tein coilovers made for a ek bolt up to a eg hatch. any help would be apprieciated thanks
Old Dec 26, 2005 | 04:58 PM
SOHC4life 96's Avatar
Default Re: will suspension from ek fit a eg? (jdm_eg94)
No, the rear forks are to narrow for the EG LCA. The fronts will fit, but not the rear.
Old Dec 26, 2005 | 05:52 PM
jdm_eg94's Avatar
Default Re: will suspension from ek fit a eg? (SOHC4life 96)
SOHC4life 96: thanks
Old Dec 26, 2005 | 10:46 PM
littleredcivic's Avatar
just change out the rear strut mount bushing and it will fit. use the one for the EK... cheap.
Old Dec 27, 2005 | 12:59 AM
skankz_em1's Avatar
Default Re: (littleredcivic)
it'll work, my friend has some kyb's from his 00 si and put it on a 93 si
Old Dec 27, 2005 | 01:06 AM
t0ekn3e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">just change out the rear strut mount bushing and it will fit. use the one for the EK... cheap.</TD></TR></TABLE>
will work if you do that.
Old Dec 27, 2005 | 09:50 PM
jdm_eg94's Avatar
does anyone know how much the rear strut mount bushing for ek cost?
thanks
Old Dec 28, 2005 | 06:12 AM
prothane or energy will cost you under 20 bux. dealer cost is around 6 each for OE rubber ones.
Old Dec 28, 2005 | 06:18 AM
d16rice's Avatar
O.E.M. EG struts have brackets for brake lines.
EK struts do not have those brake line brackets.
If you use EK struts on EG, you have to figure out a different way to mount your brake lines.
Old Dec 28, 2005 | 08:31 AM
whoDAT's Avatar
or you can grind them down. that's what i did to my gsr rear lca's in order to accomodate some tein flexes that were made for ek's.
Old Dec 28, 2005 | 10:24 AM
grinding will work as well...i like grinding... but with an EG, the bushings are old and should get swapped anyways. if they are high spring rate coilovers, new bushings are for sure a good idea. i will post a pic later of what my 8k omnis did to a rubber bushing. its nice.
Old Dec 28, 2005 | 11:38 PM
skoolz4loserz's Avatar
i'm planning on doing this as well. i have Tein SS coilovers from an EK that are going on my EG and i'm planning on gettin either OMNI or NAR-SPEC Lower Control Arms. How do i get the bushings out so that i can put the EK ones in? Hydrolic Press i'm guessing??
Old Dec 29, 2005 | 07:44 AM
yes a press. the bushings come out easy if you have the right tools. if you are going to replace the lower arms, just take them to a shop and have them do it real quick. it takes a few minutes.
93bluehb
Jan 16, 2007 06:33 PM
TORQUE MONSTER
10
Jun 21, 2006 07:52 AM
skoolz4loserz
Suspension & Brakes
10
Nov 3, 2005 06:04 PM
i20444406
Mar 13, 2005 09:48 PM
RHDintegXsi
Suspension & Brakes
Mar 11, 2005 08:38 PM
