Car Bogs Out WTF?
Old Dec 26, 2005 | 02:59 PM
artificeexks's Avatar
Default Car Bogs Out WTF?
Ok, I have a problem with the car bogging around 2000 rpm in first and second gear. I drive a 00 civic si so could it be the map sensors i suppose or the oil level being too low? Any help would be greatly appreciated!
Old Dec 26, 2005 | 03:06 PM
Mugen112's Avatar
could be an ignition problem or a clogged cat. Hard to say with a 2000 civic.
Old Dec 26, 2005 | 03:10 PM
Default Re: (Mugen112)
I recently replaced the cat, spark plugs, and spark plug wires, so im so freaken confused rite now. It was running fine after I did an oil change and it started back up again. I check the oil level and it was a little low so could that be the problem or could it be the tps?
Old Dec 26, 2005 | 03:50 PM
egtwincam's Avatar
Default Re: (artificeexks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artificeexks &raquo;</TD></TR><TR><TD CLASS="quote">I recently replaced the cat, spark plugs, and spark plug wires, so im so freaken confused rite now. It was running fine after I did an oil change and it started back up again. I check the oil level and it was a little low so could that be the problem or could it be the tps?</TD></TR></TABLE>
make sure your spark plug wires are fully seated and spark plug gap is correct!...
Old Dec 26, 2005 | 07:35 PM
Thanks for the response, that's what i was going to do next
Old Dec 26, 2005 | 07:50 PM
speedooo's Avatar
Default Re: (egtwincam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtwincam &raquo;</TD></TR><TR><TD CLASS="quote">
xJohn18
11
Jan 27, 2011 06:03 PM
1CaMw0nDeR
Jul 1, 2008 07:31 PM
LEVEL4
Aug 31, 2006 06:42 AM
fjt
Nov 23, 2004 08:52 AM
mongoliandonuts
Aug 27, 2004 11:51 PM
