Very Interesting (Integra One Make Race series)
there have been a lot of talk about the JDM sus set ups as having stiffer fronts. I was at the japanese site for the Integra One Make Race (DC5) series and this is what I saw in the suspension parts section:
front spring 14K
front spring 16K
front spring 18K
rear spring 26K
rear spring 28K
rear spring 30K
rear spring 32K
front sway bar 24mm
rear sway bar 24mm
rear sway bar 25mm
y
shi - found it interesting how ALL the available springs are stiffer in the rear
http://www.hoa.jp
front spring 14K
front spring 16K
front spring 18K
rear spring 26K
rear spring 28K
rear spring 30K
rear spring 32K
front sway bar 24mm
rear sway bar 24mm
rear sway bar 25mm
y
shi - found it interesting how ALL the available springs are stiffer in the rearhttp://www.hoa.jp
It's interesting how rather than exchanging the front and rear spring rates, they just make the rear stiffer than the front.
So instead of going from 18k/16k to 16k/18k, they go from 18k/16k to 18k/30k.
they must use the same size tires (F&R) on those kaas.
All of the approved parts are m00gen also
Thanks, my Japanese is ... not as good as yours!
the r00z state the minimum as 1050kg
y
shi - who'd like the let the metric impaired that 1050kg = 2315lbs
B18C5-EH2
Feb 6, 2018 01:50 PM
B18C5-EH2
Suspension & Brakes
Feb 5, 2018 01:38 PM
coblankenship
24
Jun 3, 2014 09:12 AM
