GSR rear sway bar for my 2000 Civic Sedan
Old Dec 26, 2005 | 06:48 AM
Dark_Ferio's Avatar
Default GSR rear sway bar for my 2000 Civic Sedan
I just got a rear sway bar from a Integra GSR(14mm) 97 I believe and I want to know what specifically do I need in order for this to work & where to get it from & is it a big deal if I don't get a front sway bar?
All your help is needed. I have a 2000 Civic LX sedan & trying to upgrade my sloppy suspension so I found this sway bar for cheap & need your help.....
Old Dec 26, 2005 | 06:18 PM
Dark_Ferio's Avatar
Default Re: GSR rear sway bar for my 2000 Civic Sedan (Dark_Ferio)
someone tell me something!
Old Dec 27, 2005 | 04:41 PM
Dark_Ferio's Avatar
Bump....I searched but got unclear results
Old Dec 27, 2005 | 05:28 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Ferio &raquo;</TD></TR><TR><TD CLASS="quote">Bump....I searched but got unclear results</TD></TR></TABLE>
you did?
I got results looking at posts from this afternoon in this forum. I can't be bothered to find them, but try a little harder....
oh... I researched it a while ago too, and found all the info clearly laid out as well... but I can't for some reason be bothered to search for you for those either...
I know that it is there though.
Good luck.
Old Dec 27, 2005 | 06:14 PM
Dark_Ferio's Avatar
Default Re: GSR rear sway bar for my 2000 Civic Sedan (SuperSlow)
So buy the 99-00 SI end links and then buy what? I've heard from bushings to d-brackets to buying a reinforcement kit for a stock sway bar.......Someone with some clear results who knows what they are talking about pleez help a brotha out!
Old Dec 28, 2005 | 07:10 AM
Dark_Ferio's Avatar
bump!
Old Dec 28, 2005 | 08:17 AM
SuperSlow's Avatar
look up ASR.
Then decide that you don't want to spend the money. Install your gsr bar with si endlinks and new bushings/dlinks. drive around and see if your bottom tears out.
You have not been searching. You probably will not get your answers bumping this.
Old Dec 28, 2005 | 10:18 AM
EeeJayEight's Avatar
seriously... just go to search.. set the button to archives... select forum as 92-00 civic/del sol and type "gsr endlinks" or "gsr sway bar"
anything remotely close to that will give u all the info you need..
if u cant find it PM me and ill give u the link
Old Dec 28, 2005 | 12:09 PM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">look up ASR.
You have not been searching. You probably will not get your answers bumping this. </TD></TR></TABLE>
IMO, the ASR subframe reinforcement is an over kill for a stock GSR rear sway.
Old Dec 28, 2005 | 12:18 PM
pdiggitydogg's Avatar
you need em1 endlinks and em1 D brackets
Thats it. Nothing else.
In no way shape or form do you need any bracing for a stock 14mm bar
Old Dec 30, 2005 | 08:53 AM
Dark_Ferio's Avatar
Default Re: (pdiggitydogg)
Thanks...I just wanted to be sure!
Old Dec 30, 2005 | 09:02 AM
swifty4u's Avatar
Call me crazy, but I know that civic and integra suspension are identical, so how would a STOCK gsr sway make stock suspsenion tear out? I've only heard of that happening on cars that are raced competitively with huge sways.
Ruben19
Suspension & Brakes
May 7, 2010 12:56 PM
jdm-yoda
Dec 11, 2007 12:27 PM
MustWonder
Suspension & Brakes
Nov 12, 2007 02:05 PM
unknown2
Sep 2, 2004 06:29 PM
SE7EN3S
14
Aug 23, 2004 01:02 PM
