LSD tranny with 4.266 FD?
Old Dec 25, 2005 | 06:30 PM
eag36's Avatar
Default LSD tranny with 4.266 FD?
Hey guys,
I'm going to be putting a lsd in my tranny this winter and i'm looking to keep my 4.266 final drive. Can i use a itr lsd and re-use the stock LS FD gear? or will i need to go with the quaife or another brand? I'm assuming obx is still something to stay away from... too bad... soo cheap.
So second part if the itr lsd won't work i'm open to suggestions as to which companies make a good lsd. I would prefer an actual limited slip to a torque biasing like the quaife, but if the quaife gets good reviews i'll be persuaded.
Thanks
Old Dec 26, 2005 | 05:47 AM
eag36's Avatar
Default Re: LSD tranny with 4.266 FD? (eag36)
bump
Old Dec 26, 2005 | 08:02 AM
Platinum Playa's Avatar
if you are adding lsd to your LS tranny you must purchase a 4.4 counter and final drive.
Old Dec 26, 2005 | 08:34 AM
eag36's Avatar
Default Re: (Platinum Playa)
ah *****. Oh well, 4.4 isnt so bad.
for that matter i might as well just buy a usdm itr tranny
Old Dec 26, 2005 | 10:14 AM
well i u have the money go for it. it would be cheaper to put the lsd into the LS, though.
Old Dec 26, 2005 | 02:09 PM
eag36's Avatar
but would it me as strong as the itr tranny in terms of being able to hold the same amount of power?
Old Dec 26, 2005 | 09:57 PM
yeah, its the same LSD.
Old Dec 27, 2005 | 03:25 PM
eag36's Avatar
no i mean the rest of the gears/syncros and such. Will a type r tranny hold the same power in terms of not chipping teeth or blowing itself apart
Old Dec 27, 2005 | 08:58 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (eag36)
The quaife is going to hold up a lot better then the oem type r LSD. But then you wont have the nice final drive.
Im in the same boat as you, im going with a quaife LSD in my LS tranny w/ a light flywheel and exedy stg 2 clutch. Should be fine for me.
blue_hatch
Jul 21, 2010 01:18 PM
killacam20
Apr 12, 2005 09:13 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
importimage
Oct 14, 2003 11:38 AM
FreeMyndz v.FP
Dec 30, 2001 07:44 PM
