Aluminum Vs. Steel
Old Dec 25, 2005 | 04:51 PM
BlueLude94's Avatar
Default Aluminum Vs. Steel
What kind of diffeance is there in using aluminum charge pipes over steel?
I assume the aluminum is the better choice due it dissapating the heat but is it THAT big of a differance?
Old Dec 25, 2005 | 05:48 PM
xenocron's Avatar
Default Re: Aluminum Vs. Steel (BlueLude94)
Weight and the fact that Aluminum wont heat soak as much as steel.
iBrandon's Avatar
Default Re: Aluminum Vs. Steel (xenocron)
nore rust...
Old Dec 25, 2005 | 06:41 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Weight and the fact that Aluminum wont heat soak as much as steel.</TD></TR></TABLE>
i think its the opposite when it comes to aluminum, i have done some test and aluminum in all its thin-ness seems to hold heat much more throughout the entire piping.
where as steel (stainless) as i tested seem to dissipate and draw it towards the outside of the pipe.
now im not a engineer grad BUT, the guntubes on on the M1A1 tanks i work on are made from steel with an aluminum thermal shroud, i would have to say due to durability and its strength the steel does a better job, we then slide a "pretty" looking aluminum shroud over it.
Old Dec 25, 2005 | 07:22 PM
xenocron's Avatar
Default Re: Aluminum Vs. Steel (mrbsponge)
Aluminum will dissipate heat much faster than steel...at least thats what I remember from college physics.
That and the fact that all heat exchangers are made of aluminum
Old Dec 25, 2005 | 07:26 PM
2point2's Avatar
it's fricken light!
Old Dec 25, 2005 | 07:32 PM
darkdayz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Aluminum will dissipate heat much faster than steel...at least thats what I remember from college physics.
That and the fact that all heat exchangers are made of aluminum </TD></TR></TABLE>
yup and as the guy said rust issues
Old Dec 25, 2005 | 09:31 PM
BlueLude94's Avatar
Default Re: Aluminum Vs. Steel (darkdayz)
I was kind of looking at it from a perfomance issue, what kind of gains would result in a switch from SS to Al
Old Dec 25, 2005 | 09:56 PM
Ti3d in's Avatar
Isn't AL going to heat up much faster also since it isn't as dense as steel? Think of an aluminum cooking pan.
Old Dec 25, 2005 | 10:20 PM
D@nnY's Avatar
Default Re: Aluminum Vs. Steel (Ti3d in)
how about think of an aluminum radiator....it takes the heat out of the charge air and releases it ...
ntoxicatedtigah
Feb 7, 2009 11:09 AM
HT Chaplain
Welding / Fabrication
Jan 25, 2008 06:23 PM
JDM92Bubble
Feb 20, 2007 02:27 PM
fafsa
Dec 16, 2004 08:56 PM
Burgh
Oct 21, 2004 07:29 AM
