what is anyone's opinion on changing gears without using the clutch?
Old Dec 25, 2005 | 02:51 PM
2006Si's Avatar
Default what is anyone's opinion on changing gears without using the clutch?
Old Dec 25, 2005 | 02:53 PM
lohatch's Avatar
Default Re: what is anyone's opinion on changing gears without using the clutch? (2006Si)
ask yourself the same question in 6 months.
it's there for a reason..
Old Dec 25, 2005 | 02:54 PM
2006Si's Avatar
Default Re: what is anyone's opinion on changing gears without using the clutch? (lohatch)
i figured....but i don't want to know six months from now, i want to know what damage it will do....does it wear out the clutch plates?
Old Dec 25, 2005 | 03:24 PM
2006Si's Avatar
by the way i meant shifting gears without changing the clutch. Sorry for the confusion
Old Dec 25, 2005 | 03:35 PM
2006Si's Avatar
i have read it can wear out your synchro's, is that true? anyone?
Old Dec 25, 2005 | 06:15 PM
B18cHatch06's Avatar
i do it all the time..this way you dont burn out your clutch of course
Old Dec 25, 2005 | 06:31 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2006Si &raquo;</TD></TR><TR><TD CLASS="quote">by the way i meant shifting gears without changing the clutch. Sorry for the confusion</TD></TR></TABLE>
This just added to the confusion. WTF are you asking!?
Old Dec 25, 2005 | 06:54 PM
EKB18C97's Avatar
^^ yea really. you need to change your clutch once it wears out. and you need to use it for shifting, hence it being there and all. what are you talking abbooooot?
Old Dec 25, 2005 | 07:08 PM
fireant's Avatar
Default Re: (EKB18C97)
clucth = a wear item that is intended to be replaced when worn out, and doesnt require a transmission rebuild.
Old Dec 25, 2005 | 09:01 PM
91B16HF's Avatar
Default Re: (fireant)
I used to do it when I was driving my pickup, never did any harm from what I noticed. Just had to catch it at the right time so it wouldn't grind.
Old Dec 25, 2005 | 09:16 PM
HiProfile's Avatar
Default Re: (91B16HF)
It won't cause a problem if you rev-match it within 100rpm. Otherwise your gears clashing together will be what causes the friction that matches the two speeds.
Only do this if on a beater - something you don't give two ***** about. Yes, it will cause more damage than using your clutch properly. If its just to impress some bitch or friend, chances are the girl won't care, and you'll eventually grind it and embarass yourself in front the girl of the friend. My opinion/experience is that you can always shift faster with more consistency when you use the clutch.
Old Dec 28, 2005 | 10:31 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
somedays, i usually only use the clutch when i come to a stop, leave a stop, or when i am driving aggressively. otherwise, it's fun to upshift and downshift without it.
Old Dec 28, 2005 | 03:21 PM
Scott_Tucker's Avatar
Default Re: what is anyone's opinion on changing gears without using the clutch? (not so civic)
If you drive your car properly the clutch is going to last 100-150k miles anyway. Are you just doing this because it is fun? You may damage your synchros or worse and it would be much more of a pain in the *** to replace or rebuild your transmission than to replace your clutch. How tolerant the transmission is to clutchless shifting depends on its design. My Civic Si is all but impossible to shift without the clutch but my 85 RX7 is smooth as butter when I do it. If it sounds like the gears or synchros are clashing then thats a pretty big indication that the transmission isn't tolerant of it.
-Scott Tucker
Old Dec 28, 2005 | 04:35 PM
xEnderx's Avatar
Default Re: what is anyone's opinion on changing gears without using the clutch? (AutoEng2002Si)
If you are really good at rev matching then it won't be a problem...thing is that as RPM's increase your response time must also increase. it gets to a point where you really can't match rev's. I used to shift my LS swap like that all the time at low revs...if you mesh up and don't grind gears then it causes no wear...thing is that there are VERY few people that are good enough to shift clutchless without grinding on a regular basis.
Old Dec 28, 2005 | 08:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEng2002Si &raquo;</TD></TR><TR><TD CLASS="quote">If you drive your car properly the clutch is going to last 100-150k miles anyway. Are you just doing this because it is fun? You may damage your synchros or worse and it would be much more of a pain in the *** to replace or rebuild your transmission than to replace your clutch. How tolerant the transmission is to clutchless shifting depends on its design. My Civic Si is all but impossible to shift without the clutch but my 85 RX7 is smooth as butter when I do it. If it sounds like the gears or synchros are clashing then thats a pretty big indication that the transmission isn't tolerant of it.
-Scott Tucker</TD></TR></TABLE>
i don't ever do this on my honda, but i do on my daily '91 mazda protege beater. forgot to add. oh i'm aware of synchro damages and whatnot, but i rebuild transmissions all the time, i guess you could say, so i'm not too worried about it. i'm pretty good at getting it right in with the rev matching. makes heel/toe'ing on point.
Old Dec 29, 2005 | 06:25 AM
91integraLSVTEC's Avatar
do a search on clutchless clutches, best kind of clutch out there
Old Dec 29, 2005 | 08:27 AM
gldndrgn14's Avatar
its better for everything if done correctly. like they stated before, for a b series youd have to have it right on the dot when rev matching, or it will be worse than using the clutch. i used to be able to revmatch and drive clutchless when i race and daily driving. but since i broke my ankle no luck no more. haha
2006Si
Acura TL, RL & ZDX
Dec 25, 2005 04:18 PM
Fez
Mar 19, 2003 11:07 AM
qWiK hYbRiD
Nov 25, 2002 06:28 PM
imported204
May 28, 2002 08:52 PM
joel
Sep 10, 2001 08:53 AM
