Clutch question
Old Mar 10, 2003 | 11:55 AM
Fez's Avatar
Fez
Default Clutch question
Will a bad clutch make it hard to put the car into different gears?
I have a hard time changing gears at high rpms, low rpms are a lil easier.
Old Mar 10, 2003 | 12:16 PM
x00gsr's Avatar
Default Re: Clutch question (Fez)
A bad clutch would make you rev higher than normal. Such as 30mph at 6k rpm. Its probaly your syncros that are messed up.
Old Mar 10, 2003 | 01:12 PM
JimBlake's Avatar
If the clutch is dragging it can make it harder to engage gears. Basically the clutch doesn't completely disengage.
Old Mar 10, 2003 | 01:15 PM
riceball777's Avatar
naw i dont think anything is wrong with your clutch. its your trannie the syncros
Old Mar 10, 2003 | 06:39 PM
thrty8street's Avatar
what clutch are you running?
Old Mar 10, 2003 | 09:13 PM
TimoneX's Avatar
New User
It may if it's the throwout bearing failing and not a worn clutch disk.
Old Mar 10, 2003 | 09:42 PM
intekragsr's Avatar
Default Re: Clutch question (TimoneX)
if it was the throwout bearing you would hear a weird sound when engaging clutch
Old Mar 10, 2003 | 09:54 PM
TimoneX's Avatar
New User
Default Re: Clutch question (intekragsr)
Usually yes and often a pulsating clutch pedal when pressed.
Old Mar 10, 2003 | 10:05 PM
Volcom's Avatar
Default Re: Clutch question (x00gsr)
You don't even have a clue nOOb.
Old Mar 10, 2003 | 10:12 PM
TimoneX's Avatar
New User
Default Re: Clutch question (Volcom)
Ouch that was way harsh. That's the description of a worn out clutch disk.
Hey Fez have you checked/changed your MTF lately? Sometimes it does the trick. You get a little moisture or the fluid loses viscosity over time. I'd try that before I did anything major. How's the clutch pedal feel BTW? Spongy...normal...extra stiff...pulsation...etc?
Old Mar 10, 2003 | 11:07 PM
Volcom's Avatar
yea, but H-T has gone downhill so fast in the past year from people like this. The misinformation that floats around here is so bad.
Old Mar 11, 2003 | 06:59 AM
Fez's Avatar
Fez
The clutch feels normal but it is hard to take out of gear at times. Seems like its not completely dis-engaging when pressed. I took it to acura yesterday and let a master tech drive it, he thinks the main problem is the clutch and suggested that I change it first. He also stated that if i wanted to rebuild it he'd do it for $300 + parts.
FYI
I changed the tranny fluid in 2001.
What clutch do you guys suggest?
Old Mar 11, 2003 | 08:33 AM
spoon94gsr's Avatar
have yor master and slave cylender checked and get it checked out before you start grinding your syncros if your already not doing it now...
Old Mar 11, 2003 | 09:35 AM
TimoneX's Avatar
New User
I'm using the action segmented kevlar clutch. I'ts terrific and cheaper than most of the other performance clutches. You can contact Rocket on H-T or go to ef1.com to pick one up. Good luck w/ you car bro.
Old Mar 19, 2003 | 06:48 AM
Fez's Avatar
Fez
I changed the clutch and flushed the clutch system with new fluid, now the tranny shifts like new.
The problem was that one of the springs on the clutch came out of the housing and got wedged between the clucth plate and flywheel.
Old Mar 19, 2003 | 08:07 AM
djtony5's Avatar
There you go.... It a common problem in Integra.
Old Mar 19, 2003 | 11:07 AM
TimoneX's Avatar
New User
Default Re: Clutch question (djtony5)
It's a common problem with all clutches when they're near the end of their life, the clutch disc comes apart. It's not Integra specific.
jdmstyleEJ6
12
May 9, 2010 04:13 PM
Pompiuses
May 31, 2005 01:46 PM
zomart
Jul 23, 2003 05:51 PM
steve_s
Apr 1, 2003 06:43 PM
