98 civic cx hatchback
Old Mar 18, 2002 | 12:40 AM
10seconds's Avatar
Honda-Tech User
Default 98 civic cx hatchback
OK. this car has the cat right at the exhuast manifold. companys dont sell a header for it or a exhaust. only the cx has this problem. if i took the exhuast manifold and cat off a dx would i have any problems putting it on the cx? if this works I can get a dam exhaust. im not ghetto so im not going to have a custom exhuast on it. i want a cat-back. let me know ASAP
Old Mar 18, 2002 | 01:25 AM
10seconds's Avatar
Honda-Tech User
Default Re: 98 civic cx hatchback (anger)
the cx cat is really right at the exhaust manifold the dx is under the car. ive seen a 98 civic hb dx and a 98 civic hb cx.
Old Mar 18, 2002 | 07:43 AM
98EK4's Avatar
Default Re: 98 civic cx hatchback (jdmimports79)
I have a 98 DX and the cat was in the front of the engine. When i done my swap i had a cat put under the car. But as Far as the CX goes it is the same as the DX. They are both infront of the Engine
Old Mar 18, 2002 | 08:42 AM
Trey's Avatar
25 Year Member
Default Re: 98 civic cx hatchback (98EK4)
Just get a performance header for an EX and use the EX cat. The cat back exhaust will need to be modified to fit though unless you throw the Cat in the garbage.
The exhaust manifold studs are the same for the CX, DX, HX and EX.
Old Mar 18, 2002 | 02:40 PM
pornstarSR's Avatar
i have a dx and its roughly the same as that motor and the ex header works....just have to add a cat right after, you can extend the 02 wires no problem and there you go, you will be surprised how much of a difference this makes on the car, but reemmber they are made for vtec cars so the power band is gona be higher up......with header exahust and few other thing the car pull at say 4000 on....pretty strongly....
Old Mar 18, 2002 | 03:00 PM
builthatch's Avatar
MiG-21 superfan
Default Re: 98 civic cx hatchback (pornstarSR)
yeah...undercar cat, cut and flange the catback and obtain an ex header (lightspeed old school) or apexi) then extend th o2 wires. other than the bolt on basics...dont invest to much in the y7 head tho.... y7 intake manifold and head is barely adequate for a micro machine. go y8 head. my old y7 head ported flowed less than the y8 head stock, b4 i got that ported too....imagine what happens when you port and cam a y8 head? your deep into dohc vtec territory.
[Modified by builthatch, 7:02 PM 3/18/2002]
[Modified by builthatch, 7:03 PM 3/18/2002]
lv6l
Nov 20, 2008 11:46 PM
bibong
Mar 22, 2008 12:42 PM
Ron454321
Feb 16, 2007 06:36 AM
djrock04
Dec 14, 2005 09:53 AM
aw1234dude
Jan 31, 2003 10:55 PM
