greddy turbo gasket. Where can i get it!
Old Dec 24, 2005 | 03:43 PM
nfinitecc's Avatar
Default greddy turbo gasket. Where can i get it!
i need the exhaust manifold - to - turbo 4 hole gasket. i have a T3 and a Mitsu T25 style and there not it. i havent been able to find one online and im out of a car!! if ya know drop me a site or #. thanks alot
Old Dec 24, 2005 | 03:56 PM
adseguy's Avatar
Default Re: greddy turbo gasket. Where can i get it! (nfinitecc)
Don't worry about it. Most people don't even run one on pieced together setups
Old Dec 24, 2005 | 04:12 PM
nfinitecc's Avatar
Default Re: greddy turbo gasket. Where can i get it! (adseguy)
i dunno about that.....has anyone had PERSONAL luck with that?
Old Dec 24, 2005 | 04:48 PM
nfinitecc's Avatar
bump it up for info!
Old Dec 24, 2005 | 04:57 PM
PnkRokCountryboy's Avatar
bump, would also like to know if its necessary
Old Dec 24, 2005 | 11:00 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfinitecc &raquo;</TD></TR><TR><TD CLASS="quote">i dunno about that.....has anyone had PERSONAL luck with that?</TD></TR></TABLE>
Yeah me and like 20 others cars I've tuned. Personal enough ? The surfaces should be smooth enough that it'll work. The carbon build up will seal tiny cracks. It's not a big deal to not run one, so if it's hard to find one don't worry about it.
Old Dec 25, 2005 | 12:01 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfinitecc &raquo;</TD></TR><TR><TD CLASS="quote">i need the exhaust manifold - to - turbo 4 hole gasket. i have a T3 and a Mitsu T25 style and there not it. i havent been able to find one online and im out of a car!! if ya know drop me a site or #. thanks alot</TD></TR></TABLE>
I was told/read on turbod16 that the T25 style would work just fine. What doesn't work about it? You should be able to use the one from an 86 Turbo thunderbird, but thats just a T25 style.
Old Dec 25, 2005 | 04:58 AM
B16Civic93's Avatar
Default Re: greddy turbo gasket. Where can i get it! (Hybrid93Eg)
i've got the greddy kit, and i dont run one, all i did was buy some of that copper gasket spray and spray it on both surfaces, and before i did that i took my dremel with the wire brush and polished the surfaces of any tiny rust pits etc...
just make sure both surfaces are pretty flat and use that copper gasket spray on it to seal any imperfections and you'll be fine
hope it helps
Old Dec 25, 2005 | 05:40 AM
nfinitecc's Avatar
Default Re: greddy turbo gasket. Where can i get it! (B16Civic93)
well i went and got the only gasket available from mitsubishi , its too square, its a small T3 rectangle, my friend had his greddy kit with no gasket and it leaks when its cold and sounds like ****. has little white heat markson the mAni, of course if it was perfectly flat im sure that wouldnt happen. i just dont wana risk it.
Old Dec 25, 2005 | 08:11 AM
B16Civic93's Avatar
it isnt a t3 its a t25 or a t28 i'm not sure which it is,
did he put that copper gasket spray on it?
that stuff works pretty good
Old Dec 25, 2005 | 09:55 AM
DRAGLS's Avatar
go to a nissan dealer and order one for a 300zx tt . Thats were i get them from.
dewoine
Jan 28, 2009 06:47 PM
boostincoupe
Aug 17, 2004 05:31 AM
kabaroo
Apr 8, 2004 11:16 AM
93dx--hatch
Mar 25, 2003 11:59 AM
project dc2
May 24, 2002 02:09 PM
