Gaskets for Greddy kit
Old Mar 24, 2003 | 07:24 PM
93dx--hatch's Avatar
Default Gaskets for Greddy kit
I just purchased a used greddy turbo kit for my B16, I am going to need new gaskets for it. Where could i buy the gaskets?
Could i just use a stock gasket for the manifold and then just make the rest of them myself?
Old Mar 24, 2003 | 07:35 PM
Aeka GSR's Avatar
New User
Default Re: Gaskets for Greddy kit (93dx--hatch)
eh? I just re-used the stock manifold gasket. It doesnt come with one.
As far as any other gaskets I think you might need to get them from GReddy.
Old Mar 24, 2003 | 08:16 PM
Default Re: Gaskets for Greddy kit (Aeka GSR)
I can't find them on the greddy site, I need all the gaskets
Old Mar 24, 2003 | 09:23 PM
91CivicSi's Avatar
What gaskets do you need? I know you'll need one for the turbo to downpipe..not sure where to get that. The downpipe to downpipe you can get at a muffler shop. DO NOT use a gasket between the manifold and the turbo. I tried to make a gasket for it 3 times..they all blew out. Just bolt them together and enjoy. Good luck!
Old Mar 25, 2003 | 12:42 AM
allbottleb16's Avatar
Default Re: Gaskets for Greddy kit (91CivicSi)
for the manifold to turbo gasket, I believe you can use a 89'-94' mitsubishi eclipse turbo gasket as long as your turbo has a 6cm housing. If you have the bigger 7cm housing try roadraceengineering.com they have all those gaskets.
As for the other gaskets you can probley get away with re-using your manifold gasket( I've pulled mine apart probley 10+ times with the same gasket)
Old Mar 25, 2003 | 09:07 AM
has anyone else not used the manifold to motor gasket??
I have never heard of this
Old Mar 25, 2003 | 11:22 AM
JalopySiR's Avatar
Default Re: Gaskets for Greddy kit (allbottleb16)
The Greddy Td04 4 bolt discharge bears no resemblance to a DSM turbine discharge. 4 bolts are all they have in common. You can probably reuse gaskets if they are in good condition. Also, most people in here don't use gaskets all. not between the turbo to Manifold, not from the turbo to DP, either...
Old Mar 25, 2003 | 11:59 AM
Default Re: Gaskets for Greddy kit (JalopySiR)
I guess I will just not use gaskets at all
dewoine
Jan 28, 2009 06:47 PM
boostincoupe
Nov 9, 2004 11:09 AM
DuNkiN
Aug 6, 2003 04:26 PM
uneekcrx
Sep 7, 2002 11:19 AM
project dc2
May 24, 2002 02:09 PM
