NPT Male to BSP Female Fitting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang »</TD></TR><TR><TD CLASS="quote">do they have a NPT male/BSPT female though...that's what he asked for</TD></TR></TABLE>
Yes McMaster and many other people sell this exact fitting. If you are using this to go into your block then GET THE BSPT ADAPTER!
And the website is http://www.mcmaster.com/
Merry Christmas
Merry Christmas
The part # is: 4860K151
1/8th Male NPT X 1/8th Female BSPT/
The only reason I would think you would need this is if you really dont want to mess up your stock pressure switch. Thats where I used it, so I could keep my stock dummy light and not mess up the threads on the stock switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
The only reason I would think you would need this is if you really dont want to mess up your stock pressure switch. </TD></TR></TABLE>
I guess...but I'd much rather have a gauge that tells me the pressure than rely on a light that tells me when there is NO pressure
Ohh and a defi BF gauge can't hurt the inside of the cabin anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">I guess...but I'd much rather have a gauge that tells me the pressure than rely on a light that tells me when there is NO pressure
I have the Defi gauge
I just use a firewall distribution oil feed setup and a backup light never hurts since it cost me all of 4$ for the fitting.
Here are some old pics to show you the fitting I am speaking of.
</TD></TR></TABLE>I have the Defi gauge
I just use a firewall distribution oil feed setup and a backup light never hurts since it cost me all of 4$ for the fitting.Here are some old pics to show you the fitting I am speaking of.
long complicated story lol to cut it short...my oil pressure switch is threaded into a golden eagle sandwich adapter now.
Ill have my eye on it the next few days though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 »</TD></TR><TR><TD CLASS="quote">long complicated story lol to cut it short...my oil pressure switch is threaded into a golden eagle sandwich adapter now.
Ill have my eye on it the next few days though...</TD></TR></TABLE>
It should be fine as long as you used Teflon tape. Although your oil pressure switch will never be the same. This is most important only when tapping the feed line into the block.
Hence this male BSPT to female NPT adapter seen above in the lower pic.
Ill have my eye on it the next few days though...</TD></TR></TABLE>It should be fine as long as you used Teflon tape. Although your oil pressure switch will never be the same. This is most important only when tapping the feed line into the block.
96 GSR-T
Oct 15, 2006 04:00 PM
